How much would I be over paying?
There is a few things wrong I see
I don't see a point in having coaxial speakers with tweeters. Kinda a waste of money
The amp is overpriced
I mean the labor is somewhat accurate.
Wouldn't waste the time with labor. That's a 3 hour job if that. Head unit is already wired. The 8 gauge kit you already have could be used to repull a nice 1/0 kit with a distro block for both amps. RCA's, amp, speakers....all of it could be had on amazon alot cheaper.
I'm not handy with car audio AT ALL! So installing myself isn't a good option.
Currently whipping a O4' GMC Sierra 2500
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
Flowmaster Super 10's
Magnaflow High Flow Cats
G2 4:88 running gears
New cooling system
Superchips Flashpaq programmer
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
8 Gauge Memphis Power wire
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
38x13.5 Toyo Open Country M/T's
18x10 Fuel Mavericks (-44 offset)
Diamond plate bed gaurds
Diamond plate tool box
Recon Xenon Bulbs in Highs,Lows,& Fogs
Recon LED Tail lights
AMP Research Automated steps
I'm eliminating the tweeters cause I also agree that it is pointless.
What amp would you recommend then? He told me that my head unit should be powerful enough to run the speakers since I'm happy with the volume of my speakers, but just want a richer, cleaner sound.
The problem with shop installs is that most of them don't usually let you bring in equipment for THEM to install. You usually forced into buying their overpriced equipment. In your case though I would really save myself the money on the amp and ditch it. Then down the road you can pick one up online for cheaper and install it yourself. The components should still sound very clean even without an amp
They allow you to bring in your own equipment. They install anything as long as you pay for install. And yeah I'm thinking about ditching the amp. It would make the SQ better but even without it, it would be an improvement from stock.
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
New cooling system
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
You should learn. Because once something goes wrong your not going to want to spend more money for someone else to fix it.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
From a shops point of view that seems about right.
just like they said up there I would ditch the tweets.
If they let you bring your own equipment I would look into different equipment and have them install it for you. Will save you a bunch of $
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
While I agree it would be a good skill to learn, If the shop installed it, they will fix it no matter what, for free. If it is beyond repairing, they replace it for free. I know this because I've had to use their "Warranty" before.
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
New cooling system
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
Since I'm very new to car audio, what equipment should I bring in for them to install instead of installing their own?
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
New cooling system
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
That is ture of most good shops they will stand behind it for life and if its out of factory warranty they should offer a deal on replacements .It's not always about save a few bucks it's more then that .
its expensive.. not over priced
for $1700 you can do a lot
So I'm not necessarily paying too much, just paying a lot. lol well good to know.
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
New cooling system
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
Its hard to tell you what equipment to get. There is a ton out there. Best bet is to do a lot of research and looking around seeing whats out there. This site is full of great info.
Hell you are from FL. There are a bunch of people from Fl on here maybe you can hook up with them and they can help you out
