GeorgeK Posted January 13, 2015 Report Posted January 13, 2015 im going to make a new box 15hx36wx26d,1 in mdf, 2 HDC4 12 on AQ3500, now im tryn to figure out the aero port. say same dimensions 5 cubes, i know 1 6" 9" long is 32 hz, 28.26 port area. but now 2 6" 30" long ( does that mean both are 30" long or 15?) 32 hz 56.52 port area i know these subs like the big port area, but is the 1 6" good enough cuz of the efficiency of it being aero port or the 2 6" better? anyone know? im useing a slot port driver side but port area is off (4" wide 13 high) and not sounding like i want. i will end up buying another AQ3500 and more batts. btw this is my first big build always had sealed boxs and under 1000watts now ive stepped up a bit. any help would be greatly appreciated. 2 Team Fi 12's2 SQ 3500's (Strapped @ 2ohm)Singer 320amp 6 phase alternator1 xs d4800 (hood)2 xs d3 100 (trunk) 1 Northstar 400 (trunk)KN Cai
pa-pa-platypus Posted January 13, 2015 Report Posted January 13, 2015 1 6" isn't really enough for optimal performance... loudest box i build for my pair was 2 6" and i had a single 8" box that was just a few tenths off This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
OrionStang Posted January 13, 2015 Report Posted January 13, 2015 Length is for each port. I'd do a 6" per sub (for 12s). SMD Super Seller My Feedback Thread
GeorgeK Posted January 13, 2015 Author Report Posted January 13, 2015 6" per sub @ 30" long correct? having some of it external matter? 2 Team Fi 12's2 SQ 3500's (Strapped @ 2ohm)Singer 320amp 6 phase alternator1 xs d4800 (hood)2 xs d3 100 (trunk) 1 Northstar 400 (trunk)KN Cai
GeorgeK Posted January 13, 2015 Author Report Posted January 13, 2015 btw itll be mostly for daily unless i can make it interchangable port for spl 2 Team Fi 12's2 SQ 3500's (Strapped @ 2ohm)Singer 320amp 6 phase alternator1 xs d4800 (hood)2 xs d3 100 (trunk) 1 Northstar 400 (trunk)KN Cai
OrionStang Posted January 13, 2015 Report Posted January 13, 2015 Yes, 30 each. External will change your box volume and tuning, so play with the calculator to get the tuning you like. Also consider the space you have in the vehicle for external ports. SMD Super Seller My Feedback Thread
GeorgeK Posted January 13, 2015 Author Report Posted January 13, 2015 whoops i posted this in the wrong section just read a guy getting reamed in another post ima see if i can delete this lol ima post this in the correct place 2 Team Fi 12's2 SQ 3500's (Strapped @ 2ohm)Singer 320amp 6 phase alternator1 xs d4800 (hood)2 xs d3 100 (trunk) 1 Northstar 400 (trunk)KN Cai
OrionStang Posted January 13, 2015 Report Posted January 13, 2015 You can't delete it, just ask a moderator to move it to the right spot. SMD Super Seller My Feedback Thread
n8ball2013 Posted January 14, 2015 Report Posted January 14, 2015 please post int he right section. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
