1 run of 1/0 or 2
hey guys friend of mine plans on running a system in his 2009 gmc denali. He plans on running 2 powerbass asa 600.4 amps on 6 selenium 8s and 6 power acoustic nx5 tweets, he has 2 powerbass asa1500.1 amps on 2 powerbass 3xl152. For electrical he already has a 270 hoa and 2 kinetic 2000 batteries 1 up front and 1 for the back the question im trying to ask is 1do I need 2 runs of 1/0 wire for positive or will 1 be enough? second should I run negative run from front battery to rear battery or frame ground? let me add I asked him does he plan on upgrading and he swears he not going any higher then that. I know the power wire he has is cca and ive always heard ofc is much better
What's the total current draw of the system?
not really sure to be honest he hasn't installed yet. the reason we are trying to figure out is if we only do 1 run we can do it through the truck if we do 2 pos and 1 neg it has to be under the truck so we want to start off right with the best option
Like Miguel said add up the fuse ratings that will give you your max potential current draw.
So if it's ofc 2 runs.
Forgot you said he has cca do you know what brand the wire is?
  • Who's Online   0 Members, 0 Anonymous, 3464 Guests (See full list)
