turning gain down to lower power ?
chris j m
ok guys , my original plan was to get a b2 zero.7 amp to run two fi sp4s ,
only now a good deal has come up, and for cheaper I can get a b2 serum 7k .
I have a dd1 so I know I can get clean power
if I get the 7k , would I be able to set the gain to put out only 6k or 7k rms to the subs ?
the rms rating of the b2 7k is 8,500 rms at 1 ohm ,I have seen a few dyno videos on the b2 amps and they seem to do rated and then some .
am I going to be risking sending way too much power to the subs if I use this amp , even with the gain turned down ??
Cheers
You'll be fine
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
The subs should be able to take what that amp can give if it's clean power and the amp is set up with an O-scope or a DD-1. Many run those subs on similar power(or more), so you should be fine. The enclosure will determine part of what is safe and what isn't as well.
