Resting voltage
DMM them right at the led. Is it a Stinger volt meter your using? If so, they can be adjusted to read diffent voltages. Great right a volt meter that you have to program to read the correct voltage. Well at least the one I smashed on the ground when it broke after 2 weeks did.
added did oops
Boy you drunk, lol!
Why you like the great stinger volt meters?
No, I'm a little high and when I first read it I thought it said "great right". Hell naw I hate stingers. For that reason and they suck
12.5 is low. usually its 12.6.. each cell should be at 2.1v
throw it on a charger a few times and they will start to rest at 12.8. i got a few xs power d3100 that would sit at 12.6 and after a few charges they rest at 13.1 over night. back then they would drop to 12.6 in a hour
Now when I charge them Do i have to do both seaprately the front and back or will charging one charge both at the same time and how long you say it takes? Will a battery tender be ok? like this one?
http://www.sears.com/battery-tender-021-0128-12-volt-1-25-amp-battery-charger/p-SPM2694072221
or this?
or
http://www.sears.com/diehard-battery-charger-maintainer/p-02871219000P?prdNo=1
what be good
http://www.sears.com/search=car%20battery%20tender
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
  • Who's Online   0 Members, 0 Anonymous, 2926 Guests (See full list)
