BassMunky Posted February 6, 2015 Report Posted February 6, 2015 I have a diehard battery platinum up front and a optima yellowtop group 31 in back on a rf amp 1500. when my car off the battery rest at 12.5 is that good or bad? my stinger is hooked up to the amp and reads 12.5 when offf and when im moving it goes to 13.9. both battery are about 2-3 years old. What is everyone voltage at? Car was offf for about 5 hours Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
poorfish88 Posted February 6, 2015 Report Posted February 6, 2015 DMM them right at the led. Is it a Stinger volt meter your using? If so, they can be adjusted to read diffent voltages. Great right a volt meter that you have to program to read the correct voltage. Well at least the one I smashed on the ground when it broke after 2 weeks did. added did oops
BassMunky Posted February 6, 2015 Author Report Posted February 6, 2015 whaaa? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Kyblack76 Posted February 6, 2015 Report Posted February 6, 2015 12.5 is just fine.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Silverado297 Posted February 7, 2015 Report Posted February 7, 2015 12.9 in the driveway is where I'm at with 3 stinger 2150s and a yellow top pushing a 7k
Ahmed Johnson Posted February 7, 2015 Report Posted February 7, 2015 DMM them right at the led. Is it a Stinger volt meter your using? If so, they can be adjusted to read diffent voltages. Great right a volt meter that you have to program to read the correct voltage. Well at least the one I smashed on the ground when it broke after 2 weeks did. added did oops Boy you drunk, lol!
poorfish88 Posted February 7, 2015 Report Posted February 7, 2015 DMM them right at the led. Is it a Stinger volt meter your using? If so, they can be adjusted to read diffent voltages. Great right a volt meter that you have to program to read the correct voltage. Well at least the one I smashed on the ground when it broke after 2 weeks did. added did oops Boy you drunk, lol! Why you like the great stinger volt meters?
ChevyBoy95 Posted February 7, 2015 Report Posted February 7, 2015 Use an actual Digital Multi Meter (or DMM) and check the voltage. I personally wouldn't like my batteries resting at 12.5v, even though that isn't bad, they might need to be thrown on the charger more often. Stinger Volt Meters are nice for a general read out, but by no means are they "accurate." Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
