ok just a quick question i seem to be kinda confuse if i have a sub and its a dual 2 ohm and have it positive to positive and negative to negative how many ohms does it come out to on the amp.
it has two possibilities
1 ohm or 4 ohm
depending on how u wire the coils
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
wiring in parallel like you said would be a 1ohm load.
Team Pinnacle / Team SouthEastSPL / Team SoundStream / Team GPI / GPI Sales Rep for Florida and Georgia
next time name your thread please
Edited by Chode69
NoFearX18 said:
trainman0978 said:
add another sub..
your choices with a dual 2 are: 1 ohm parallel or 4 ohm series..
Follow my Tweet (Twitter)
Guest MegaloManiac
you cant. unless you have that Stinger Accumatch.
edit: or add another sub like meade said
Edited by MegaloManiac
also if you want to add another sub you will get either a .5 or a 2 or an 8 ohm load depending on the wiring configuration.
NoFearX18 said:
trainman0978 said:
