what to use in corners of box
BigManAC
your resonant frequency will change depending on equipment as well. bigger box takes up more space, ect...
Its sealed off and the front of both boxes will be in the exact same position so it shouldnt change.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
When dealing with a strictly burp box, you can and a lot of times will, go outside of manufacturer recommendations. The recommendation that Fi is giving is got a box that plays music.
I'm smelling what you're cookin! Makes sense.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
When dealing with a strictly burp box, you can and a lot of times will, go outside of manufacturer recommendations. The recommendation that Fi is giving is got a box that plays music.-
okay, any idea how big? somewhere around 18-20?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
^No one is going to be able to tell you. You need to build and test. Without getting into the whole sqin of port per cube thing, 16 per is a good middle of the road starting point to get a base line. Next you could try 18, if you gain keep raising port area until you stop gaining. The scientific method is your friend here haha
Team NorthWestSPL
Yeah I see your point. Since every car and every build is different what might work for one might not work for another.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
I agree with mrd6, no one can tell you. Building and testing I'd the only way to find out. Start with a certain port, then try a different. Build a box with the ability to do a removable port, that might be worth trying rather than doing a slot port
Like a square or PVC removable port?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
A square or a plate with some PVC or aeros, it's really up to you.
Alright ill get busy in torres and see what I can come up with.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
  • Who's Online   0 Members, 0 Anonymous, 852 Guests (See full list)
