kmb504 Posted February 11, 2015 Report Posted February 11, 2015 Has anyone built an enclosure for a vfl8? I read that at .7ft3 tuned to 34hertz these subs sound amazing. I just cant seem to pencil whip theses numbers to make that work. Can someone help? Or give their opinion for box size, tuning and demensions. Ive got one 8. My max demensions are 30w x 12d x 17h
Triticum Agricolam Posted February 11, 2015 Report Posted February 11, 2015 Small, low tuned boxes can be really difficult to design. To get enough port area the ports almost always end up being a mile long. If you post what you came up with so far we can probably point you in the right direction. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
kmb504 Posted February 11, 2015 Author Report Posted February 11, 2015 I cant seem to get my numbers to work. If I do 10d x 20w x 14h thats gives me 1.14 ft3 gross volume and if I do my port 22l x .60w x 12.5h its gives me a tuning of 34.24 hertz and gives me .71ft3 net volume. The sub displacement is .073ft3. Isnt .60" a little skinny for a port?
kmb504 Posted February 11, 2015 Author Report Posted February 11, 2015 I really just want someone to tell me what to build lol
Triticum Agricolam Posted February 11, 2015 Report Posted February 11, 2015 Yeah having your port being .6" wide is not what you want to do. Generally you want your port aspect ratio to be under 5:1 and the closer to 1:1 you can get it, the better. At .6" wide and 12.5" tall that's about 20:1. You probably don't have enough port area either. How much power are you going to run? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ChevyBoy95 Posted February 11, 2015 Report Posted February 11, 2015 I have done boxes for single 8's that were low tuned (30-35hz), never really turned out well due to what Triticum said. Port was super long, had to wrap around, and even when i had the tuning, port area, and perfect volume it just didnt perform. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
kmb504 Posted February 11, 2015 Author Report Posted February 11, 2015 Around 650 rms so what would you guys recommend?
Triticum Agricolam Posted February 12, 2015 Report Posted February 12, 2015 At that power you are going to want to have around 14-16 sq in of port area, which means your port is going to need to be about 43" long or so to get you tuned to about 34 Hz. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Joe X Posted February 12, 2015 Report Posted February 12, 2015 Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 1 1/2", figure is just an assembly guide:
