2 HDC3 15s Ideas?
KO4Life
Damn man did you build them boxes in your sig? Those are bad ass, here's one of what i cam up with but I would like to try 36hz. Question I have alot of problems with is the port area I am seeing I need 144sqin of port wtf?
Yup, I've built all those, thanks for the compliment.
For port area, you are going to need a lot. 144 sq in would probably be a good number. You might be able to get away with a little less, but I wouldn't go below 130 sq in. If you are tight on space I'd give of some of your internal volume for a little more port area. At 8.6 cubes you are a bit on the high side anyway.
Builds:
The hard part of your project is the baffle dimensions, net airspace you seem to have enough although you will surely need to build inside, I was able to get around 130 square inches of port area on your baffle dimensions and still be able to fit the subs.. like this:
If you think you can build something like the above correctly then you can make subs/port forward work on your dimensions.
Welcome good work always deserves a compliment, yeah I was wondering how much port area I could sacrifice but I might be able to squeeze a Lil more in the front of box, that's a crazy looking box there. But if I can get a nice speced box with some good port area for around 4k watts or so I'll be very happy and that box looks complicated too build lol
Budget Banging On A Budget.....
99 Civic EX Coupe
XS Power/SkyHigh Powered
Build In The Making...
This is another alternative easier to build but this one looses you some net airspace:
Which to build depends on how much space you can get and from where, pretty much no one wants to do one of these things but sometimes it's necessary.
Question I always wonders was why are some ports just straight in and why is the reason for L ports? Another thing is the box is going in and more than likely not going to be back out, how much do you charge to design me a box?
99 Civic EX Coupe
You turn the port when it needs to be longer than the depth of the box (for example), when it turns it gets that L or T shape, you may want to remeasure your space to avoid building something more difficult than it needs to be, if I can do something for you it will be at no cost.
Thanks , but I would not let you do it for free.
99 Civic EX Coupe
I did however squeeze a few more dims, I now have 36.5wx18.5hx37
99 Civic EX Coupe
Bump................
99 Civic EX Coupe
  • Who's Online   1 Member, 0 Anonymous, 518 Guests (See full list)
