Hi..
I want some advice about which sub-setup I would go for..
15x10" ,8x12" or 6x15"...
The problem I see are the size of the box, I only have about 8-9cubic feet to deal with..
And I want to go with subs up/port back...
I will give the subs about 7-8Kw.. and it´s in my Jeep Grand Cherokee -00 this setup is for..
The goal for me with this build is to build a show-car that can do hair-trick, be able to score +150db with music..
Do you think it´s possible or am I way of...???
I´m not the best in write in english so I hope you still understand me.. ;-)
//Hallin
Edited by Hallin
Hi..
//Hallin
I think that you will have a prob with space man honestly with that amount of woofers you might be able to pull of 4 15's with your back seats folded down. If you have 8k look into some btls or maybe some audioques and with the right electrical and a good box you would probobly would be close if you know what your doin.
hope that helped
Youtube.com/J Hutch22
if 8-9 cuft is external volume then I would prob try to squeeze in 4 15's and even at that you will be cutting it close. After material, port and spkr displacement you really don't have that much room, definitely not enough for 6 15's if you want it to sound right on music. With that kind of power the loaded BTL's would be a good choice.
Also you have to think about where all the batteries and amps will go, if that is not figured into the max space for the box then you will loose even more space and may want to consider 4 12's
Edited by sully
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
i dont think he'd be able to get 4 15's in there at that. unless he went a lil below minimum recommendations. minimum for a btl is 3 cubes, he'd need 12 for 4 of em. that's about average for a 15 incher. give or take. he'd be better off with trying 4 12's with that space
  • Who's Online   1 Member, 0 Anonymous, 1226 Guests (See full list)
