those miles to E crap are so incorrect you will gain 75 miles when you first start cause youre idling but when you drive around itll drop quick to a tad more accurate figure. if you measure the voltage right after you started then your car was probably idling a bit high till the engine warms up and itll drop and bring the volts down to the 14v range and as for the air bag sensor, i have no clue you should probably make your dealer look at that cause you dont want a faulty air bag.
Your problem is that your ecm (cars computer) is flipping out!!!
I get my airbag light to come on all the time when Im showing off with excessive voltage, once i get around 16.3-4 going through my ecm.
Id try disconnecting all your battery(s) then cranking your car to make sure your vehicle is fully drained on juice, then reconnect the battery(s).
Unless your car was fine before with the 15 volts, but that be my best bet.
  • Who's Online   0 Members, 0 Anonymous, 3996 Guests (See full list)
