Orion Hcca 12.2 Box Help?
ibanezrg134
I recently bought an Orion Hcca 12.2 and am trying to build a box for it and have a few questions. I am putting roughly 1500 watts towards it.
This is Orion's recommended box size.
1. Orion recommends a square port. Is there any benefit to a square vs slot port?
2. Orion recommends a 38 hz tuning. Isn't that a little high for rap. I was thinking 33-35 would sound better.
3.My working dimensions are h= 20 w =40 and d = 15. Sub up port up.
Any help would be appreciated!
And by doing the slot port right isn't there a ratio to reduce port noise?
Lower like 35 or 32 is very common.
2007 ford freestyle. Hifonics brx2400.1d( budget build). Going to set gain to output around 1500 watts at one ohm.
I believe the ratio is 1/8, you want to be as close to a 1/1 ratio as possible. And ideally a vent match below .05
2014 JKU
Sound:
pioneer xav-65
4 12in pioneer tsw3003d4
2 pioneer gm-d9601
(much more in route)
General:
18in worx rims
33in tire
stinger src bumpers
light bars
6k hids
2in leveling kit
3.25in lift
The Build Log: http://www.stevemeadedesigns.com/board/topic/195839-2014-jku-build-4-12s/
1/1 being same height and width?
And could you elaborate more on a vent match?
For example a 4in wide x 20in tall port would be a 1/5 ratio. Vent match refers to the speed at which air comes out of your port.
2014 JKU
Sound:
pioneer xav-65
2 pioneer gm-d9601
General:
18in worx rims
33in tire
stinger src bumpers
light bars
6k hids
2in leveling kit
3.25in lift
is there anyway to control the vent match?
Yeah, larger port area = lower vent mach
Builds:
Don't forget to mention that if you increase your port area that in most cases it will raise your tuning and that you'll have to make your port longer to account for the increase in port area.
2014 JKU
Sound:
pioneer xav-65
2 pioneer gm-d9601
General:
18in worx rims
33in tire
stinger src bumpers
light bars
6k hids
2in leveling kit
3.25in lift
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
