Need box help for (2) Sundown SA8 V2 using 5/8" MDF
sundownaudio
Need box help for (2) Sundown SA8 V2 will be throwing 550rms each to them @ 1ohms, plan on using using 5/8" MDF (3/4" not available). Thank you
Vehicle - 2007 Toyota Premio
Amp Hifonics / BRX 1100.D
32x11x18
No 3/4" wood sadly
So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 2 1/2", figure is just an assembly guide bracing is a 1 1/4" wooden dowel rod:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
By this "NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside" you mean to see if it will fit in my car ? and also those edges do they have to be 45's or can i leave them straight ?
sa8x2.jpg'
Not to thread jack,but where do you get your sub sonic filter numbers from? I've noticed that a lot of the times you say 28hz. I'm just curious.
2014 JKU
Sound:
pioneer xav-65
4 12in pioneer tsw3003d4
2 pioneer gm-d9601
(much more in route)
General:
18in worx rims
33in tire
stinger src bumpers
light bars
6k hids
2in leveling kit
3.25in lift
The Build Log: http://www.stevemeadedesigns.com/board/topic/195839-2014-jku-build-4-12s/
Yes the note is there to remind you that you should make sure a box will fit into the trunk before building, you should not have any problems but I want to make sure, you don't have to do the slanted cuts but round the sharp edges at the ends and at the turn, if nothing better you can just sand a little,
  • Who's Online   0 Members, 0 Anonymous, 2966 Guests (See full list)
