wats the difference between a slot port and a square port
cant seem to find the answer anywhere
Alpine CDA-9886
2x DC lvl4 15s
SoundStream PCA2000D
6 cubic feet
tuned 32hz
Our deepest fear is not that we are inadequate. Our deepest fear is that we are powerful beyond measure. It is our light, not our darkness, that most frightens us. Your playing small does not serve the world. There is nothing enlightened about shrinking so that other people won't feel insecure around you. We are all meant to shine as children do. It's not just in some of us; it is in everyone. And as we let our own lights shine, we unconsciously give other people permission to do the same. As we are liberated from our own fear, our presence automatically liberates others.
a slot port uses a wall of the box as one (or more) port walls and requires a correction in the calculation
a square port uses none of the box walls. (i.e. has 4 pieces of wood to make the port)
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
ok i think i get it now
thanks!
Alpine CDA-9886
2x DC lvl4 15s
6 cubic feet
tuned 32hz
the shape and about 2db. :P
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
2db meaning the square port?
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
I would like some info on this question too.
I threw a box together one day that wanted a 4 inch diameter port,so I picked a corner of the box and did a square port somewhere around 3.75x3.75x the length and it pounded but I had port niose bigger than shit.
So there is something I'm not getting with a square port unless you can't use one of the corners for 2 of the walls of the port.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
ok so im trying to get this right
if my box dimensions are
H 17
W 31
D 16
its 4.17 ft^3
im using a square port
H is 13"
W is 3"
the length should be 10.6"?
**correction H is 14" for the port
and tuning is at 40hz
Edited by Eclipsebooom
Alpine CDA-9886
2x DC lvl4 15s
6 cubic feet
tuned 32hz
yeah.... -2db for square.
  • Who's Online   0 Members, 0 Anonymous, 939 Guests (See full list)
