2014 focus sedan factory Box
dsw422
This is one of the rare times that I disagree with JoeX. I would suggest you do not try to replace the factory head unit, unless you really want to take on a difficult project. In these newer Ford cars all the signal processing (left/right balance, front/rear fade, bass/treble, subwoofer crossover, etc) is all done in the factory amp that is most likely hiding somewhere in your trunk. If you replace the head unit you have to replace that amp too and its going to be a ton of work and expense. Not to mention there is usually a bunch of vehicle functions that are integrated into the factory HU that are going to be hard, if not impossible, to get to work with an aftermarket HU. I've used a LOC wired to the sub output on these ford systems and it worked great, so that is my suggestion.
I like JoeX's box design though :-)
So the LOC needs to go after the amp and not before the amp?
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
It depends on how your factory amp is setup. I've done two late-model ford installs in the last year, one was in a F-150 and that other was in a Focus. On the F-150 I tapped into subwoofer inputs coming from the HU going into the factory amp and didn't need to use a LOC. On the Focus there were no separate subwoofer inputs going into the factory amp, the crossover to the sub was done in the amp so I had to use a LOC wired to the amp subwoofer outputs.
I don't know how your car will be setup, you will have to figure out how its wired now and decide how you want to do it based on that. No matter how it is, using a LOC wired to the sub outputs on the amp should work though.
Builds:
That subwoofer is one of the main reasons I got a base model Focus ST! I knew it would be useless if one were expecting any real bass. That being said, I also will not be replacing even my base model head unit because I feel like the basic Sync system does everything it needs to and does it well.
To get the signal out of my factory HU I'm going to be tapping into the front two channels behind the HU and running it into an Audiocontrol LC2i. This post pretty much details the rest of my plans, but have not yet decided on amplifiers :)http://www.stevemeadedesigns.com/board/topic/195236-2014-ford-focus-stsundown-sa-8-v2-d2-custom-enclosure-advice/
I'll be interested in seeing what you come up with if you plan to fiberglass a box into that corner of the trunk, best of luck!
i actually like the system in my car, but just want a little more boom.. the other 9 speakers in the car sound amazing.. and yea, i definately wont be touching the HU.
As for hooking up a LOC, ill most likely do triticum said.. just tap into the sub wires..
im interested in seeing/building it too!! lol..
thanks
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
hey triticum,
i went through your builds and saw you made a box for 1 15 for a focus hatchback.. what were your dimensions if i can ask?? i just built a box for a budy for 1 15 in a 2013 focus hatch..
heres the thread.. http://www.stevemeadedesigns.com/board/topic/195074-box-for-hcca-15-d4/
1994 Ford Bronco
Sony door speakers
hey triticum,
Sure, the dimensions were 40-1/2" wide x 18" deep x 13-3/4" tall, it fit about as close to perfect as I could hope for.
Builds:
The box I made was a bit bigger.. i was off though a little on my width.. i just trimmed the corners so it'll fit.. I've got final coat of paint on it now a d will b put back in Monday or Tuesday.. hopefully I trimmed enough
1994 Ford Bronco
Sony door speakers
It's more like I just overlooked it's one of "those" vehicles anyhow in many cases this won't stop anyone more serious about car audio. OP I know you are at the entry level and it's all good to do a quick fix to improve, just a reminder, there's cool stuff to be had if you ever want it.
  • 5 months later...
Found this thread searching for info on what to do with my 14 Focus SE Hatch.
Found this
http://www.sonicelectronix.com/item_52517_Metra-99-5827B.html?utm_source=google&utm_medium=cpc&utm_campaign=PLA&scid=scplp3792620&gclid=Cj0KEQjwx_WuBRDJ7tSK2-W0pJkBEiQAEWgR8Nes4DOUvZBfNUdpHfg6TbWDGe3D3KD6Ddhqa_7DqSEaAseM8P8HAQ
Biggest issue for me is finding alternator power. I can fit 1 battery and 3.7net cubes in the hatch area and keep it below the cargo cover. So 1 15 is the best option. I've also considered removing the back seats and walling off behind the driver seat. 2 18s maybe? I dunno. Just getting ideas. ATM I'm digging the CT Sounds EXO 15.
Current Setup : Nothing
2014 Ford Focus SE Hatch
Future looking like:
Singer / XS power
Crescendo BC3500D
CT EXO 15
Pioneer 80PRS
CDT HD-61PRO
CT Sounds M75.4
CT Sounds AT60.4
Something along those lines.
Found this
which head unit do u have?? i am keeping my factory one since it is the touch screen...
i built a box for my buddy in his 2013 hatch. i was for a HCCA 15. i forget total size.. but it was a perfect fit with notches in the side to hold it in place.. Under the cargo cover too!!
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 3894 Guests (See full list)
