Solder size and ratio?
I don't like silver solder. Doesn't seem to wick as readily. Never saw much of a difference from various ratios. Just make sure you use rosin core, not acid core. Acid core corrodes connections over time. Tub of rosin flux helps too
This is the dumbest question of the century coming up but I'm asking anyway. Would it be okay to dip the power wire into the flux and then dunking it into the terminal or is that completely stupid?
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
Thats how i like to do it. Keep the solder and terminal hot though or you will fuck it up. I fill them about 3/4s full....I honestly use a crimper now though, its cheaper and a bit easier and cleaner..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Were you replying to me with dunking the wire into flux and then dunking it into the terminal?
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
Do your self a favor and use a vice if you can. i tried using channel locks to hold the terminal on a few and ended up cutting them off cuz i didnt like how they turned out.
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Will do. Thank you.
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
