Ahmed Johnson Posted March 10, 2015 Report Posted March 10, 2015 I'm thinking it's not giving a good tone thru the rca'a. I did take it to a place and he thought it was not a powerful enough amp to push it. Any way to see how many watts coming out of the amp? The amp is plenty powerful. The sub you got, if I'm not mistaken is 1000 rms. At 2 ohms that amp is gonna give you that.
garton05 Posted March 10, 2015 Author Report Posted March 10, 2015 Subs rated at 1200 but hoping it will be close 1998 Pontiac bonneville SE Alpine Iva-w205 touchscreen. Phoenix Gold Titanium Elite 12 AQ2200 amp Kinetik HC 3800 battery Big 3
CleanSierra Posted March 10, 2015 Report Posted March 10, 2015 My guess is something with the head unit, like the bass is off or something to that effect. You might have a bad RCA in the back of the head unit if it's verified indeed be on and turned up(bass label setting in the head unit). My suggestion is take your ride to a professional that knows what they're doing and what to look for. By the way, the ground has NOTHING to with the amp turning on or not. The Remote turn in is what powers the amp up, you could disconnect the power wire from the amp and as long as the remote wire is still plugged in, the amp will light up and turn on. You've got some magical amps sir.I was tired when i posted. Did I make a mistake with the remote turn on information?My suggestion for him to take his vehicle to a shop was 100% accurate. Im not the one you want to try to troll. Just a fyi for you.
garton05 Posted March 10, 2015 Author Report Posted March 10, 2015 1998 Pontiac bonneville SE Alpine Iva-w205 touchscreen. Phoenix Gold Titanium Elite 12 AQ2200 amp Kinetik HC 3800 battery Big 3
matt14 Posted March 10, 2015 Report Posted March 10, 2015 Is you LPF set to 20hz? 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
pa-pa-platypus Posted March 10, 2015 Report Posted March 10, 2015 try it without the bass knob if you haven't already.. wortha shot This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
thefourth Posted March 10, 2015 Report Posted March 10, 2015 Didn't read all of it but maybe try a pair of RCA's with the aux input into your phone or something. Easiest way to tell if it's the headunit Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
