box for 2 dss ethos 15
d-nice88
But seriously can I make the ethos work in those dimensions?
The first things to ask you is if you can do the box somewhat larger, what vehicle is it and what amp. Not to say it can't be done and neither saying you won't be satisfied with the results but since you will need to significantly cut port area from what is specified by the manufacturer you will take some performance hit, mild or not so much, it would be a good idea to talk to the owner if he is available either for feedback or even a layout if he is willing to do it.
Amp is perfect, not sure the backseats will fold down in that vehicle though and also increasing your max dims even if it is 1 inch or two would be very helpful.
Its kinda hard since I cant make the box any wider at all since it wont clear the opening of the trunk and I can only make it deeper if I make it shorter im basically at my max for real in this buick. Those dimensions wont work for the ethos so they def wont work for the hds 300?
If you really want to fit the two 15's you're going to have to build the enclosure inside the trunk.
The HDS315 are going to need more than 3 net so no I don't think that those would be a better option, is more like what it says in the post above, building inside and a little bigger, actually 16 x 39 x 31 1/4" would be enough IMO.
Are you planning to compete or is the build just for personal enjoyment?
  • Who's Online   0 Members, 0 Anonymous, 5219 Guests (See full list)
