crescendo 800/4 problems
brent379
Attach copper wire loop around rca cable outer housing ..find correct screw size to attach ring to any screw hole on back of deck.
do you have a pic of this completed?
Consider there may be a bad channel from the head unit causing clipping and putting amp into protect. Has the system been DD_1'd to make sure signal is clean?
yes i have dd1'ed everything several times.
On your 3.5 what are you wired at? How's your electrical..maybe amp has internal issues.. Lot of vibrating shakes parts loose.
starting at .5.....last time i checked i was rising up to 1.4 at the minumum. have a dc 270xp, 9a35 under the hood, big 3 in 1/0 shca ofc, will be adding a 9a31 once i get money for wire. right now most of the time my voltage is between 12.3 and 13...charging at 14.7 when hot.
I'm guessing not enough current for 3.5 running .5 load is tuff on amp.you may have created a issue in the amp making a part weak..get a battery or two in there ..
I'll try get a better picture idea for you after work ..if I remember
nevermind dude. dont need the pic. found a couple different ways to do it. got to love google :good:
  • Who's Online   0 Members, 0 Anonymous, 600 Guests (See full list)
