Which amp would you suggest?
dmel
What amp would this forum suggest for a pair (2) American bass xfl 10s
rms: 1000/2000w
220oz magnet
2x2 impedence
P.S. I had a Rockford 1000.1d mono block to begin with but I am looking for more basssss!
Could get a 2nd fosgate amp if they are 1 ohm stable, would be cheap and nice. Also could go for a matching American Bass amp but really this is a personal choice, just go with one of the many brands known to do good power.
If you have 2 dual 2 ohms subs then an amp that is known to put out 2k at 2 ohms.
If you have 2 dual 4ohm signs then an amp that is known to put out 2k at 1 ohm.
Problem solved.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Get a matching Rockford amp and run one amp to each sub at 1 ohm.
The bad thing is, i already sold the rockford to upgrade. The rockford that i had they didnt make anymore, they updated/upgraded to the 1200.1d. And i really dont know how well american bass subs are. I heard good and ive heard bad, im not really sure if i overpowered them if they would handle what a 1200.1d would give?
Truth is if you buy a true 1200 watt rms amp it's not likely the subs will even ever see that much power and it's not at all bad to have some headroom anyways.
With subs rated 1000 rms there should be no problem with an amp that puts out a clean 1200 rms.
Right, im just not that familiar with the subs themselves, longevity wise anyways. If i had purchased two rockford 1200.1d amps would i need a bigger alternator? I am running a rockford 250x4 to my door speakers as well. I have a second battery running in the trunk already.
What vehicle and do you know what size your stock alt is?
Sometimes you can get away with 2k on a stock alt most likely you'll need to upgrade though.
I had a 02 Malibu stock alt yellow top up front and xs d2400 in back ran a Crescendo bc 2k a .5 ohm to a pair of sa 12's for over a year no problems whatsoever. Very solid amps! clamped it doing 2014 watts with rise to 1.4 ohms
Youtube.com/J Hutch22
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
