Broke_Audio_Addict Posted March 25, 2015 Report Posted March 25, 2015 Recommending Batts now without even knowing what he's running, sounds about right. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
420c Posted March 25, 2015 Report Posted March 25, 2015 Another thing to check is where your amp is grounded. Does it have a clean connection and is it the best location for your setup.
Mustang2dakota Posted March 25, 2015 Report Posted March 25, 2015 I'm just going to assume that your problem is worse at idle. Try holding your vehicle at ~1800rpms and see if that helps any, if so It sounds like you need to do the big 3 and get a bigger/nicer batt. 2014 JKU Sound: pioneer xav-65 4 12in pioneer tsw3003d4 2 pioneer gm-d9601 (much more in route) General: 18in worx rims 33in tire stinger src bumpers light bars 6k hids 2in leveling kit 3.25in lift The Build Log: http://www.stevemeadedesigns.com/board/topic/195839-2014-jku-build-4-12s/
ShowtimeElectronics Posted March 25, 2015 Report Posted March 25, 2015 You can go with one of the CE Auto Electric Big 3 Kits. Theyre high quality and should help your situation. I do agree with others that you should look to upgrade your battery as well. If you let us know the year/make/model of your car, we can point you in the right direction. http://showtimeelectronics.com/product-brand/ce-electric/ Showtime Electronics Authorized Dealer For Many Popular Brands Including XS Power, Kicker, McLaren, Beyma, Ampere Audio, DC Audio and more! Site: www.showtimeelectronics.com eBay: www.stestore.net Amazon: www.amazon.com/shops/showtimeelectronics Email Us : [email protected]
Broke_Audio_Addict Posted March 25, 2015 Report Posted March 25, 2015 Really? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
m0rtin Posted March 26, 2015 Author Report Posted March 26, 2015 big 3, but plz explain what you mean by the bass shorts out........ do you mean the sub amp goes into protect? amp isnt going into protect mode. its more like the bass goes out on heavy bass parts of the song when bumping at loud volumes or even half way. like there isnt enough power feeding the subs n amp when it needs it. i adjusted my positive/power wire with inline fuse and doesnt seem to cut out at all anymore. but still thinking of just doing the big 3 soon myself
m0rtin Posted March 26, 2015 Author Report Posted March 26, 2015 What is the equipment used and how does the electrical look like? stock battery and alt. 4 gauge wiring with 2 P3 12s and kicker zx.1000.1
m0rtin Posted March 26, 2015 Author Report Posted March 26, 2015 The big 3 is not a cure all. I'd like more info as well, what do you mean it shorts out? when listening to a song... i can turn up the volume at max clean signal then after awhile bass cuts out on heavy bass notes, id turn the volume down a lil bit n bass bumps again. depending on the song n low bass notes.
m0rtin Posted March 26, 2015 Author Report Posted March 26, 2015 What IS* your voltage drop.....??? dont have a dmm so i dont know how much my voltage is dropping while bumping
m0rtin Posted March 26, 2015 Author Report Posted March 26, 2015 Do the big 4 to start then upgrade to a the biggest agm battery underhood that will fit. (XS Power). We will be better to help you with knowing what equipment you our running. Where is your amp grounded to? How did you set your gains? amp is grounded to a good spot on the body of the car near the trunk and bask seat. gains were set using a dd-1
