PurpleSnow Posted March 27, 2015 Report Posted March 27, 2015 I looking to get bit more out of my subs the setup I've had for a while was ok but since i really started playing around i saw so many new designs in boxes this is close to what i had in W 35.4 x H 15.75 x D 15.75 ports 8 x 3 it played everything quite good so for my first try i build this box but with the port at the top facing up into the cab W35.5 x H 15.7 x D 19.7 port was 2.7 x 12 x 12 it didn't play so good was quite a bit of distortion tried rotating in diff positions as well I even tried lengthening the port down and in in L shape if im making sense but didn't do much good. I then borrowed a box from a friend and so far it is the best one W 33.5 x H 15.75 x D 17.7 port 3.5 x 17.7 x 11.81 but now my question is there anything i coulda done better with my build. my sub specs are Starsound SSW-S12-3500 D4 Max output: 3500w RMS: 800w FS: 28.1 Re: 2x4ohm Res: 92.7ohm Qms: 5.5 Qes: 0.39 Qts: 0.37 Vas: 56.4L Mms: 207.1 Cms: 0.15 BL: 27.2 SPL: 87.9 Xmax mm / in.: 25 mounting hole: 304-8 - 6.5 depth: 152mm Sealed: 21-45 ltr Vented: 45 ltr 90mm tube by 300mm my amp is a bit small im only running 4ohm at the moment on the 2 subs cant do 1ohm unfortunateley
Broke_Audio_Addict Posted March 27, 2015 Report Posted March 27, 2015 Your top and middle design looks like the port/ports were getting choked off at the rear of the enclosure. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
PurpleSnow Posted March 27, 2015 Author Report Posted March 27, 2015 Your top and middle design looks like the port/ports were getting choked off at the rear of the enclosure. Your top and middle design looks like the port/ports were getting choked off at the rear of the enclosure. the pics i posted were just exhamples not presice. the top one the ports were at least half the ;length of the box
Ahmed Johnson Posted March 27, 2015 Report Posted March 27, 2015 I'm sorry if I missed it but what kind of vehicle you putting this in?
Joe X Posted March 27, 2015 Report Posted March 27, 2015 W 33.5 x H 15.75 x D 17.7 port 3.5 x 17.7 x 11.81 but now my question is there anything i coulda done better with my build. This one would seem the better of the 3, should be around 4.4 net @ 25Hz, you should tell what do you mean by "best" though.
