Just bought a Sundown nsv3 12" d2... Need some help
Does it still make the noise if you pull it out and free air it?
Some pics still would help
Edited by Broke_Audio_Addict
I got home and listened to it, the sound I would have to compare it to is like a nut shaking on something steel, so steel on steel vibrating. Free air will probably have to wait until tomorrow, and it's dark here with no good light source so terrible pictures, the enclosure is basically limiting me from taking it out inside the car, and the enclosure is a tight fit.
The only picture I have right now: https://onedrive.live.com/?cid=e191037107272722&id=E191037107272722%21152&sff=1&v=3 sub is in same side as port
My uncle who was heavy into car audio for about 10 years is saying it sounds like the coil, so it's sounding like it's a faulty woofer that needs sent back while I still can.
Edited by Reely Neme
Just sounds like unlinearity in the motion of the moving masses causing the coil to slap the sides of the gap.
I suggest finding a sweep from roughly 20Hz-80Hz and see if it goes away with higher frequencies.
Krakin's Home Dipole Project
I'd just give sundown a call or whatever vendor you bought it from and I'm certain they will handle it for you.
  • Who's Online   1 Member, 0 Anonymous, 1504 Guests (See full list)
