Ahmed Johnson Posted April 3, 2015 Report Share Posted April 3, 2015 The BC3500 is strappable and I think he's saying the SQ4500 is at 10% interesting cause ive heard that the sq4500s are very clean amps but if they arent clean then thats fine, ill go with 4-3500Ds. strapped at 1ohm per pair I don't know if they are clean or not. I know the power ratings they gave were at 10% THD at the time I was looking. Link to comment Share on other sites More sharing options...
Miguels Posted April 3, 2015 Report Share Posted April 3, 2015 they are 1 ohm Power @ 18V** @ 10% THD my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Andrew Storlie Posted April 3, 2015 Author Report Share Posted April 3, 2015 The BC3500 is strappable and I think he's saying the SQ4500 is at 10% interesting cause ive heard that the sq4500s are very clean amps but if they arent clean then thats fine, ill go with 4-3500Ds. strapped at 1ohm per pair I don't know if they are clean or not. I know the power ratings they gave were at 10% THD at the time I was looking. as of right now... right off the site it claiming just over 9k strapped 1ohm at 1%THD Specifications Model Q1-4500D.1 Digital Monoblock 1 ohm stable Input Sensitivity 0.2V ~ 5V Variable Low Pass Filter 20Hz ~ 200Hz @ 24dB/Slope Subsonic Filter 10Hz ~ 50Hz @ 24dB/Slope 2 amp linkable connection Output Master / Input Slave Clipping Display Led On Remote Gain Control Signal to Noise Ratio 85dB < Damping Factor 250 < Efficiency 85% at 4 ohm < External Fuse Rating 400 Amp in-line, 800 for pair Tested Voltage 14.4V Working Voltage 9.5V ~ 18.5V** 4 ohm power @ 12V @ 1% THD 750W x 1 4 ohm power @ 14.4V @ 1% THD 1400W x 1 2 ohm power @ 14.4V @ 1% THD 2280W x 1 1 ohm power @ 14.4V @ < 1% THD 4560W x 1 1 ohm Power @ 16V** @ 1% THD 5500W x 1 1 ohm Power @ 18V** @ 1% THD 6900W x 1 1 ohm Power @ 18V** @ 10% THD 7546W x 1 2 ohm Linked Power @ 14.4V @ 1% THD 9120W x 1 2 ohm Linked Power @ 16V** @ 1% THD 11650W x 1 2 ohm Linked Power @ 18V** @ 1% THD 14000W x 1 2 ohm Linked Power @ 18V** @ 10% THD 15092W x 1 Dimensions (mm) 657.2mm (L) x 241.3mm (W) x 66.7mm (H) Dimensions (in) 25.875in (L) x 9.5in (W) x 2.625in (H) Power and Ground Inputs 0 Gauge x 2 Link to comment Share on other sites More sharing options...
Miguels Posted April 3, 2015 Report Share Posted April 3, 2015 somehow i think the Q1-4500 is a rebadge Q1-3500.. didnt the 3500 did 4300 at 1ohm? my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Andrew Storlie Posted April 3, 2015 Author Report Share Posted April 3, 2015 somehow i think the Q1-4500 is a rebadge Q1-3500.. didnt the 3500 did 4300 at 1ohm? well from there site: Clean RMS power on 13.8v standard electrical system: Ohm Load BC3500d 1ohm 3875 2ohm 1900 4ohm 1150 Dimensions: BC3500: 21.25"L x 2.75"H x 9.5"W (at widest point) so looking at about 3800rms per sub, but thats starting at 1ohm, ill be running .5ohm Link to comment Share on other sites More sharing options...
Popwarhomie Posted April 3, 2015 Report Share Posted April 3, 2015 They are rebadged 3500s. But also "tweaked" to put out 300 more watts. 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build. Link to comment Share on other sites More sharing options...
Miguels Posted April 3, 2015 Report Share Posted April 3, 2015 somehow i think the Q1-4500 is a rebadge Q1-3500.. didnt the 3500 did 4300 at 1ohm? well from there site: Clean RMS power on 13.8v standard electrical system: Ohm Load BC3500d 1ohm 3875 2ohm 1900 4ohm 1150 Dimensions: BC3500: 21.25"L x 2.75"H x 9.5"W (at widest point) so looking at about 3800rms per sub, but thats starting at 1ohm, ill be running .5ohm oh no son..im talking about the sounqubed amp.. i know the crescendo are clean my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted April 3, 2015 Report Share Posted April 3, 2015 The BC3500 is strappable and I think he's saying the SQ4500 is at 10% interesting cause ive heard that the sq4500s are very clean amps but if they arent clean then thats fine, ill go with 4-3500Ds. strapped at 1ohm per pair I don't know if they are clean or not. I know the power ratings they gave were at 10% THD at the time I was looking. as of right now... right off the site it claiming just over 9k strapped 1ohm at 1%THD Specifications Model Q1-4500D.1 Digital Monoblock 1 ohm stable Input Sensitivity 0.2V ~ 5V Variable Low Pass Filter 20Hz ~ 200Hz @ 24dB/Slope Subsonic Filter 10Hz ~ 50Hz @ 24dB/Slope 2 amp linkable connection Output Master / Input Slave Clipping Display Led On Remote Gain Control Signal to Noise Ratio 85dB < Damping Factor 250 < Efficiency 85% at 4 ohm < External Fuse Rating 400 Amp in-line, 800 for pair Tested Voltage 14.4V Working Voltage 9.5V ~ 18.5V** 4 ohm power @ 12V @ 1% THD 750W x 1 4 ohm power @ 14.4V @ 1% THD 1400W x 1 2 ohm power @ 14.4V @ 1% THD 2280W x 1 1 ohm power @ 14.4V @ < 1% THD 4560W x 1 1 ohm Power @ 16V** @ 1% THD 5500W x 1 1 ohm Power @ 18V** @ 1% THD 6900W x 1 1 ohm Power @ 18V** @ 10% THD 7546W x 1 2 ohm Linked Power @ 14.4V @ 1% THD 9120W x 1 2 ohm Linked Power @ 16V** @ 1% THD 11650W x 1 2 ohm Linked Power @ 18V** @ 1% THD 14000W x 1 2 ohm Linked Power @ 18V** @ 10% THD 15092W x 1 Dimensions (mm) 657.2mm (L) x 241.3mm (W) x 66.7mm (H) Dimensions (in) 25.875in (L) x 9.5in (W) x 2.625in (H) Power and Ground Inputs 0 Gauge x 2 Well if they had this up last month I might have bought one, but then again it has been on back order for a while so I might have lost patience. Link to comment Share on other sites More sharing options...
Miguels Posted April 3, 2015 Report Share Posted April 3, 2015 They are rebadged 3500s. But also "tweaked" to put out 300 more watts. more like distorted to get the extra 300 my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Popwarhomie Posted April 3, 2015 Report Share Posted April 3, 2015 The crescendo 3500 and the old AQ3500 were pretty much the same amp. 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build. Link to comment Share on other sites More sharing options...
