Amart's 04 Jimmy daily build single Fi n2 15"
Well, finished up construction on the box today.
Dusted of the old n2 for test fitting.
Cutting a test hole. Funny thing is. Fi's specs say 14 1/8" cutout which was way too big. I ended up cutting 13 7/8" which was almost a perfect fit.
Flush trim bits FTW
LOL took a break.
All rounded over.
Screw holes all filled and sanded, Almost ready for a finish.
Made some more progress today, got the power wire ran, Big 3 almost done and started on amp mount.
Drilly time.
Some lube to make things easier ;)
Damn east coast rust. Gotta so prevention.
cb19a3c7-4f3f-4aca-b00f-d9263a0e11dd_zps
Still looks rough, will make it pretty later.
Not how i'm mounting it, but looks cool.
Almost all wired, ran out of bolts. have to get some for the battery.
Sick deal on sandpaper. couldn't pass it up.
Did some staining today. Not perfect but I think it will turn out ok. Took a gamble on the color. Didn't want something too light. Should look way better after a few coats of polyurethane tomorrow.
Wood conditioner.
Put a coat on the Amp mount.
Finished putting 3 coats of polyurethane on the box. Definitely worth the headaches. literally lol
Decided to make the port black.
EDIT: That gray spot at the top of the port is just a reflection. Had to double check in person after seeing the pic LOL
After the poly
