Joe X Posted April 14, 2015 Report Share Posted April 14, 2015 Ok, here is a second drawing same specs, desired external dims, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 3/4", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Link to comment Share on other sites More sharing options...
bcbrassard Posted April 15, 2015 Author Report Share Posted April 15, 2015 Thank you sir, exactly what i was looking for. As always... you are the man. Link to comment Share on other sites More sharing options...
