Joe X Posted April 14, 2015 Report Posted April 14, 2015 Ok, here is a second drawing same specs, desired external dims, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 3/4", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
bcbrassard Posted April 15, 2015 Author Report Posted April 15, 2015 Thank you sir, exactly what i was looking for. As always... you are the man.
