Daniel Joseph Bragenzer Bond Posted April 14, 2015 Report Posted April 14, 2015 Has any one out there ever had 2 of MA Audio's HK4000D 's in parallel (strapped)?? Are they stappable??? Only thing in the Manual is under the features and controls section. says it has a parallel mode, but thats it. nothing else in the book. The only other thing showing anything is a sticker on the under side of the amp showing a wiring diagram for the parallel mode. Ive had this amp for many years and just got another. I Stapped them up how the diagram on the bottom of the amp shows. But they are Not working correctly. Like the amps are fighting each other. Diagram shows: Positive lead on both amps to the sub. no master/slave switch. and nothing on the negitive leads. plays this way. no protection light, but not correctly(horribly distorted and lack of power). Also the slave amp should have no control. but it does. I have un-strapped them and tested each one seperatly and they work fine not togethere. I also tried to add a jumper from negetive lead to negetive lead on the amps cause some require that, but it just puts them into protection mode. Back to running one now. Has anyone sucessfully Stapped these??? PLEASE HELP!!
Kyblack76 Posted April 14, 2015 Report Posted April 14, 2015 why the need to strap ? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Daniel Joseph Bragenzer Bond Posted April 14, 2015 Author Report Posted April 14, 2015 to get the same power to each sub..to use both amps as a 1 channel mono block
Kyblack76 Posted April 14, 2015 Report Posted April 14, 2015 gain match to each......is that impossible ? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Daniel Joseph Bragenzer Bond Posted April 14, 2015 Author Report Posted April 14, 2015 yes. i tried to match the gains up even tho the slave amp should have no control but it does.
Kyblack76 Posted April 14, 2015 Report Posted April 14, 2015 yes. i tried to match the gains up even tho the slave amp should have no control but it does. PUT A AMP ON EACH SUB...... also, ill bite/ask, where are you wired to ? Strapped?... 4ohm i hope? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
2loud4uboyz Posted April 14, 2015 Report Posted April 14, 2015 As Kyblack76 said. Gain match each amp. Put one amp on each sub. Gives same results as strapping I think . Hope you have good voltage. Because them amps get power hungry . But yeah they will put in work. ,
Kyblack76 Posted April 14, 2015 Report Posted April 14, 2015 2ohm. RMS Power @ 4 ohms 2000 watts x 1 channels RMS Power @ 2 ohms 4000 watts x 1 channels RMS Power @ 1 ohm Not Stable SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted April 14, 2015 Report Posted April 14, 2015 if your "strapped" (which your amp cant do) at 2 ohm,.. your at 1ohm nominal. So your hosed there...... Also, the RCA out, IS NOT FOR LINKING those amps.... amps ARE NOT LINK ABLE.. again.. ... as i mentioned above, put one amp on each driver, and gain match. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
