GS300Cali93 Posted April 15, 2015 Author Report Posted April 15, 2015 shit my bad, missed the part were it says two 15's.... sorry Lol its all good its wired to 2ohms
Miguels Posted April 15, 2015 Report Posted April 15, 2015 series or parallel... cant be both tis one or the otheryou must be a genius or something..... oh wait your information is wrong series/parallel.. see bellow So there is such thing as series parallel? yes there is.. you can wire each sub in series then parallel to the amp outputs.. it will be the same but you will use more wire my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
dbmode2 Posted April 15, 2015 Report Posted April 15, 2015 no one goes to this site anymore it is sad really http://www.jlaudio.com/header/Support/Tutorials/Wiring+Dual+Voice+Coil+%28DVC%29+Subwoofer+Drivers/Tutorial%3A+Wiring+Dual+Voice+Coil+%28DVC%29+Subwoofer+Drivers/287544 STOP BLOWING UP SUBWOOFER
SIDE SHOW Posted April 15, 2015 Report Posted April 15, 2015 you can get more power out of that amp at 1 ohm, but I don't think you can wire two 2ohm dvc subs to 1 ohm.
GS300Cali93 Posted April 15, 2015 Author Report Posted April 15, 2015 what amp is it? 1200watt prime amp Yes it is and there dual 2ohm does that help?
SIDE SHOW Posted April 15, 2015 Report Posted April 15, 2015 you can wire two 2ohm dvc woofers to either .5ohm 2ohm or 8ohm.... I don't think your amp will handle a .5 ohm load as it says tis only stable to one ohm it's a Rockford fosgate amp isn't it
GS300Cali93 Posted April 15, 2015 Author Report Posted April 15, 2015 you can wire two 2ohm dvc woofers to either .5ohm 2ohm or 8ohm.... I don't think your amp will handle a .5 ohm load as it says tis only stable to one ohm it's a Rockford fosgate amp isn't it Yea it is
islandpride684 Posted April 15, 2015 Report Posted April 15, 2015 Don't change a thing, the wiring setup you have now is fine...if you want to wire lower than 2 safely, sell those subs and get D4s... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
