Need advice for noob build. -Envoy
This is for a 2003 Envoy.
This is a small set-up I'm hoping to build. It will be for a daily driver. Let me know if there's anything wrong. Any recommendations are accepted.
First I'll be upgrading the electrical.
-Big 3
-XS S series under the hood. Quoted from website: "MAX Amps – 3300" (Biggest I can fit in the hood without modifications)
-270A Mechman alternator
Would I need to change the harness on the alternator for "voltage regulation"?
Would this setup effectively push a DC audio 3.5k amp / 1 DC Level 4 18" 2 ohm(1400 RMS)? Would I need another battery?
Is the amp overkill; or should I settle with a DC 2.0K amp? 2 ohm = 1200watts / 1 ohm = 2000watts
What amp fuse would I need to connect from the positive terminal of the alternator to battery?
Sound setup:
-DC audio 3.5k amp or 2.0k amp.
-1 DC Level 4 18" 2 ohm vs 1 ohm (opinions on 1 vs 2 ohms?)
i would run the 3.5k i loved mine and there is always room if you want to go bigger. and possibly another battery in the back and you will be solid.
2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
​MB Quart Component Sets
Pioneer 5x4s
Audiotechnix Power Wire, Speaker Wire, Sound Deadener
DC Audio Level 4 10s
DC Audio 3.5k
Rocford Fosgate R400-4
HID 6k
Slammed Truck on 20s
Candy Blue.
  • Who's Online   1 Member, 0 Anonymous, 1348 Guests (See full list)
