Guest Posted April 29, 2015 Report Posted April 29, 2015 I didn't read through all the thread so if it's been asked my bad. How and where are the amps grounded? I'm sure it won't hurt to redo the alt ground regardless You grounded the alt case to the frame? Its all good, I re-did every ground wire except the alt case to ground one so far. Every ground is "dremeled" down and connected straight to a strut on the car.
SIDE SHOW Posted April 29, 2015 Report Posted April 29, 2015 if you just run one pair of left and right rca's to each 4 channel amp, do you still have the noise?
Guest Posted April 29, 2015 Report Posted April 29, 2015 if you just run one pair of left and right rca's to each 4 channel amp, do you still have the noise? yup
Broke_Audio_Addict Posted April 29, 2015 Report Posted April 29, 2015 Hmm so the alt case is grounded to your front batt? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
SIDE SHOW Posted April 29, 2015 Report Posted April 29, 2015 Oooo that's weird as... try what broke said. I've never had this issue befor so I am just guessing at this stage
Guest Posted April 29, 2015 Report Posted April 29, 2015 Hmm so the alt case is grounded to your front batt? Yup, I got it connected to that bolt just above the arrow to the batt neg, which is double grounded to a strut.
Broke_Audio_Addict Posted April 29, 2015 Report Posted April 29, 2015 Do you have a rear battery? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Guest Posted April 29, 2015 Report Posted April 29, 2015 Do you have a rear battery? Yup, that is double grounded in the rear.
Broke_Audio_Addict Posted April 29, 2015 Report Posted April 29, 2015 OK what I would do is eliminate those grounds and run as thick of a ground wire as you can from the alt case to the rear batt and ground all your amps to the rear batt. You can even test this by running the wire outside of the car and through a window to see if it makes a difference. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Ahmed Johnson Posted April 29, 2015 Report Posted April 29, 2015 You could leave those old battery grounds but definitely do a dedicated ground from the rear to the front
