What Box Would Be Best For My Two Kicker L7 15's
Well considering I am limited by the amount of room I have I can only go so big before I am maxed out.
So does 32 hz, 5 inch port, subs up port back, and each sub in their own chamber sound good or should the box be one big open space?
You mean four 4" ports. Aero ports will add cost to the build but will help conserve your limited space. I personally wouldn't divide the box.
PUSH PULL CLAM SHELL FTMFW
-Drew
uhoh_45 said:
You would want the box open. If you are as short on space as you say, you don't want to add any more displacement then you need too.
that should be 4 inch ports, its up to you if you want 4 or 5 ports.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
Alright so it will be open space and not them having their own enclosures. However, why can't I just have on big port instead of 4?
2008 Chevy Impala (undercover cop style)
Setup in the makings
The ports I'm recommending are flared round ports. You would need a single 8" to = the same air flow and they don't make 8" aeros. You could use two 6" ports but four 4" will be cheaper.
Just going on a little bit of experience from my 15L7 I had and a few boxes I built for it, and on other peoples experiences... 6 cubic feet is not enough for two 15" L7s IMO... personally I consider that just a bit more than what is about right for just one... If at all possible, I would go with the 8 cubic feet Derrick824 suggested at a minimum.
Yeah but I don't have that room remember? It's in the back of a Jeep Liberty not a Tahoe lol. I will get the biggest I can/
One big slot or square port would have more displacement then 4 four inch ports. plus aero ports seem to flow a little more air then square or slot ports. why do you think people try to round and/or 45 the corners of slot or square ports. don't get me wrong slot/square ports are good to but the thickness the those ports is large compared to the thick of the aero port. for the people yelling at the screen, I'm not saying aero port are the best. each port has its place...
I do box designs.
subs up , port back. u should really have 4.5 cubes per sub after disp. or 8 cubes shared after disp. id always rather see big enclosure small port then small enclosure big port. since u say u only have 6 cubes then use fiberfill to help out.
  • Who's Online   0 Members, 0 Anonymous, 1068 Guests (See full list)
