zack_e89 Posted April 27, 2015 Report Share Posted April 27, 2015 I got a RF P1000 older version that calls for a 140 amp fuse and I haven't found any amp kits with these. I've seen 125 and 150...Probably shouldn't go with the 150 so what should I do? Only thing I've seen that might work is a 140a circuit breaker but I've never used one of those. 97 Suburban 8 custom PSI Platform 3 18's Link to comment Share on other sites More sharing options...
SPL.Pantie.Soak Posted April 27, 2015 Report Share Posted April 27, 2015 http://www.amazon.com/Absolute-ANL140-2-Pack-Fuses-Plated/dp/B005EUTG7Y Kenwood KVT-614 (4) Marathon 155 AH batts 2/0 OFC SHCA Mechman 370 (2) Audioque 3500.1 (2) AA Mayhem 15s Link to comment Share on other sites More sharing options...
zack_e89 Posted April 27, 2015 Author Report Share Posted April 27, 2015 Wow... Thanks 97 Suburban 8 custom PSI Platform 3 18's Link to comment Share on other sites More sharing options...
Tarball Posted April 27, 2015 Report Share Posted April 27, 2015 fuse to the wire. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
zack_e89 Posted April 27, 2015 Author Report Share Posted April 27, 2015 fuse to the wire. That's what I've done in the big systems I've had. So I thought, find a wire that needs a 140 amp fuse. Then thought I was just overthinking this....which is why I posted 97 Suburban 8 custom PSI Platform 3 18's Link to comment Share on other sites More sharing options...
