amp calls for 140a amp fuse...hard to find?
I got a RF P1000 older version that calls for a 140 amp fuse and I haven't found any amp kits with these. I've seen 125 and 150...Probably shouldn't go with the 150 so what should I do? Only thing I've seen that might work is a 140a circuit breaker but I've never used one of those.
97 Suburban
8 custom PSI Platform 3 18's
fuse to the wire.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
fuse to the wire.
That's what I've done in the big systems I've had. So I thought, find a wire that needs a 140 amp fuse. Then thought I was just overthinking this....which is why I posted
97 Suburban
  • Who's Online   0 Members, 0 Anonymous, 1061 Guests (See full list)
