3 subs to 2 amps
DylanBunch
forgot to add , your final load would be to low to strap. you need a 2ohm load. add 3 more subs, run an amp to each set. <_<
strapping at 1.6 could work... i guess..
or.. more shit will burn.... i dunno
strapping at .6 is probably outta the question.... but some do...
True 1.6 could work, but me... not going low ever again. i would be scared to strap low, i don't know enough about it.
Idk I mean when I wired my ct 7k to .35 I was pretty conservative and never ran into problems, I don't see .6 being a problem
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
each will see half..
ill never do it again either... ever...
Why not? The ampere took it fine didn't they?
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
first what amps do you have.... can they be strapped? if your running 3 dual VC subs to 2 amps, just run 3 coils off each amp. and set your gains and crosses correctly with a dd1 and cc1
  • Who's Online   1 Member, 0 Anonymous, 6623 Guests (See full list)
