audiolamb6 Posted April 28, 2015 Report Posted April 28, 2015 so ive built the box sealed is 1.2 ported is .83 port is 8 inch in dia. running off an ampere 2k . the problem im having is the sub is bottoming out at full volume . so any help would be appreciated
Triticum Agricolam Posted April 28, 2015 Report Posted April 28, 2015 What size sub? What frequencies is it bottoming out on? Do you know what the front chamber is tuned to? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
audiolamb6 Posted April 28, 2015 Author Report Posted April 28, 2015 sub is a 12" as for what frequency not really sure just got it playin tonite but id say the lower end . and as for the tuning of the front camber not really sure its 4.5 inchs long. i got the design from a friend whos used it for a lot of different subs and worked well with all of them
Triticum Agricolam Posted April 28, 2015 Report Posted April 28, 2015 OK, just so I got the number straight. The box is 1.2 cubes sealed side, .83 ported side, with an 8" port 4.5" long? Do you have the sub motor mounted in the sealed side or ported side? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Quintine Posted April 28, 2015 Report Posted April 28, 2015 Ported side is tuned around 120Hz I would personally keep that sub out of a 4th Instead try a standard vented at around 3 cubes, and use 2x 4" Aero ports @ 27" length each Should give you a tuning around 27hz, play safe @ 2kw down to around 20hz I am assuming also that you are using the 12" AA - Havoc If you leave it till the last minute, it will only take a minute. Build Log - 4x12's Trunk Firing 6th
Triticum Agricolam Posted April 28, 2015 Report Posted April 28, 2015 Yeah, I got pretty much the same tuning number as Quintine did. So basically what you have is a sealed box, with some crap in front of it that's doing nothing for you. I would recommend avoiding designs from this friend of yours in the future. Sealed boxes don't have the excursion limiting abilites of a ported box, so is not terribly surprising you are bottoming out, especially on the low notes. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Quintine Posted April 28, 2015 Report Posted April 28, 2015 They do if designed right but it seems like things are too small which can actually increase excursion (From what I have read, have not seen it happen in person*) Perhaps something like that is happening here. *If someone has a little more real world knowledge than me about effects of tiny sealed enclosures causing extra excursion please apply that knowledge strait to my face. If you leave it till the last minute, it will only take a minute. Build Log - 4x12's Trunk Firing 6th
audiolamb6 Posted April 28, 2015 Author Report Posted April 28, 2015 ok guys thank for the input . heres the reason for useing the design my car only has a ski hole and the rear deck is out of the question
audiolamb6 Posted April 28, 2015 Author Report Posted April 28, 2015 oh yeah the car is a 96 bonneville if u need to know
Miguels Posted April 28, 2015 Report Posted April 28, 2015 do .75 cubes sealed my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
