Cheap or homemade adjustable power supply?
TRON
I just need something to supply constant 5v DC to a throttle position sensor to check if its working. I'd rather not spend a few hundred on a power supply for something I'll probably use once. I'm sure there are some cheap ass units out there or some of you guys here might even know how to make something that can regulate the voltage off a 12v battery.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Red wire right? There's a yellow and red and the internet tells me its the red one.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Yeah I have dmm, what the fuck am I thinking. ^_^
Thanks for the idea, I never would have thought of that.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
  • 4 weeks later...
Alkaline batteries are 1.6v when fresh out of the box. 3 in series will give you 4.8v. Would that be close enough for your test?
this is VERY EASY....
you will need a few things:
1) a 36vdc power supply with adjustable voltage...
2) a digital buck converter
links to each
1) https://www.parts-express.com/36-vdc-97a-350w-regulated-switching-power-supply--320-3141
2) http://www.ebay.com/itm/Buck-DC-DC-Digital-Control-Step-down-Converter-Power-Supply-Module-6-40V-6A-240W-/231577143862?pt=LH_DefaultDomain_0&hash=item35eb12ca36
simply wire them up, and using the digital control you can set your constant voltage or current depending on your project...
all for about 100 bucks and will drive up to 36v at 6A
edit: i used to have the EXACT set up for testing leds and lasers. sorry i no long have pictures of the set up.
Replace 36vDC power supply with car battery and boom
why replace it? a car battery both costs more, and limits you to under 12v for testing.... the converter will drop the voltage to anything to you need
edit: and youd still have to charge the car batt. so more money and weight that is not needed
  • Who's Online   1 Member, 0 Anonymous, 399 Guests (See full list)
