Sundown SA-15 problem
So i just got my two sa 15's, and i put them in my ported box with 3 cu per sub, had it wired to 2 ohm just for testing and i was only playing them about 75% of what the amp can do on 2 ohms (its a rockford r1200, so 400 watts going to each sub max) and i started to smell the coil and i could feel the heat on the dustcap. my gains are set right, ive put an oscilloscope on it to make sure. the subs also make a very loud sound like bottoming out, which i can hear over the bass. i really dont know why this is happening and ive read such good reviews about these subs so idk. any help would be great!
How do you know how much power you are putting to the subs? How did you set your gains?
Whats the tuning on your box? What were you listening to when this happened?
Builds:
i know its roughly 800 because im putting a 2 ohm load on an amp that is rated at 800 watts on 2 ohms, i set my gains by running an oscilloscope with this subs and turned the gain up on full volume just before the wave started to flatten. box tuned to 34 hz and i was listening to rap that hits 35 hz notes
What are the enclosure specs?
Port specs?
Are you saying both sides of the enclosure are those dimensions or that's the whole enclosure because that doesn't add up right?
does this mean you have your gain set to 75% the way up?
if so that is too high
no volume was 75 percent up on the music, gains are set good i know that
It sounds to me like you are clipping them.
System:
Pioneer DEH-8400BH
4 Alpine Type R 6.5's
4 Soundqubed PA 6.5's
4 Soundqubed Supertweets
Hifonics BRX 640.4
Crescendo S800/4
2 Soundqubed Q1-3500.1s strapped @1ohm
2 Soundqubed HDC4 18's
11 Cubes net @37hz (Subs up, port back)
2 DC Power 250 HD's
1 DC Power 300 SPX
DC Power triple alt bracket
5 Kinetik HC 1800's
4 runs of 1/0 OFC power cables
4 runs of 1/0 OFC grounds from rear battery bank to OEM alt bracket
iPad Air in dash
300+ sq ft or sound deadening
  • Who's Online   0 Members, 0 Anonymous, 347 Guests (See full list)
