scooter99 Posted January 29, 2018 Author Report Posted January 29, 2018 Thank you! Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted January 29, 2018 Author Report Posted January 29, 2018 OK, done cleaning the house. Back to it for a bit. Now it was time to wire everything up, or get the wires cut to length and ready for when the lugs show up. 10K in place. Temporarily. the plan with this was to build a frame around it when I was done and make it into a new floor essentially, and then add in a thick acrylic window over the top of it. Then put a floor mat over it for daily so it didn't get scratched up or ruined. IMG_1309 by Scott Carver, on Flickr Sky High Car Audio Dual 1/0 inserts. IMG_1310 by Scott Carver, on Flickr and let the fun begin! IMG_1311 by Scott Carver, on Flickr IMG_1313 by Scott Carver, on Flickr DC 2.0K for the center console DC XL10. This would locate under the seat when all is said and done. Well, was supposed to. IMG_1314 by Scott Carver, on Flickr Sky High 1/0 inserts IMG_1315 by Scott Carver, on Flickr IMG_1316 by Scott Carver, on Flickr I know it looks sandwiched here, but there's actually a good 1/4" - 3/8" space between the top of the cable and bottom of the top panel. IMG_1317 by Scott Carver, on Flickr IMG_1318 by Scott Carver, on Flickr Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted January 29, 2018 Author Report Posted January 29, 2018 So the bbq was only a few days away, I was getting short on time, so here I am in my parking lot at work at lunch running cable. lol Don't act like you all aren't this crazy or haven't done it before! OR wouldn't do it!! lol IMG_1319 by Scott Carver, on Flickr IMG_1321 by Scott Carver, on Flickr IMG_1323 by Scott Carver, on Flickr IMG_1324 by Scott Carver, on Flickr IMG_1325 by Scott Carver, on Flickr IMG_1326 by Scott Carver, on Flickr IMG_1328 by Scott Carver, on Flickr IMG_1329 by Scott Carver, on Flickr Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted January 29, 2018 Author Report Posted January 29, 2018 That pretty much wrapped up the cabling I needed to do in the back. Then I addressed under the hood and the cables that needed to be ran back to the rear bank. This is what it started out as. IMG_1331 by Scott Carver, on Flickr IMG_1332 by Scott Carver, on Flickr IMG_1333 by Scott Carver, on Flickr My plan was, is, to run dual 1/0 cable to each side, but again, out of time so I left it with the 2/0 which was already ran on the passenger side and needed running on the driver side. I picked up these inserts at home depot in the electrical isle. This is the driver side IMG_1334 by Scott Carver, on Flickr IMG_1335 by Scott Carver, on Flickr Passenger side IMG_1336 by Scott Carver, on Flickr IMG_1337 by Scott Carver, on Flickr These things didn't like the 2/0 very much, and if I did it all over again, which I will be, I'll remove the deadener because was really playing havoc on those things making them pop out. IMG_1338 by Scott Carver, on Flickr IMG_1339 by Scott Carver, on Flickr Driver side ran. IMG_1340 by Scott Carver, on Flickr IMG_1341 by Scott Carver, on Flickr IMG_1342 by Scott Carver, on Flickr IMG_1343 by Scott Carver, on Flickr Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted January 29, 2018 Author Report Posted January 29, 2018 Ground cable IMG_1344 by Scott Carver, on Flickr IMG_1345 by Scott Carver, on Flickr IMG_1346 by Scott Carver, on Flickr New cables from both batteries to the alt. On the alt there is a 4 slot terminal. I covered it with some pipe insulation because it was pretty close to the hood. It doesn't hit, but why take a chance. I may drill out some threaded holes in the terminal and counter sink some holes in a piece of plexiglass for a cover. That way the screw heads aren't exposed. It'll look a lot nicer than that. Also new battery terminals on each battery. IMG_1347 by Scott Carver, on Flickr plus new runs between the batteries. IMG_1349 by Scott Carver, on Flickr IMG_1351 by Scott Carver, on Flickr Now back to the enclosure. IMG_1352 by Scott Carver, on Flickr IMG_1353 by Scott Carver, on Flickr IMG_1354 by Scott Carver, on Flickr Terminals on the inside are also from the electrical isle at Home Depot. IMG_1355 by Scott Carver, on Flickr Cut off the bolt ends after the nuts were on. That way they could be cleaned up before the nut comes off. Saves the threads. IMG_1356 by Scott Carver, on Flickr IMG_1357 by Scott Carver, on Flickr It's the little things! IMG_1358 by Scott Carver, on Flickr Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted January 29, 2018 Author Report Posted January 29, 2018 Now it's gonna really get serious!! I made a template based on the port size and room for play etc. IMG_1359 by Scott Carver, on Flickr IMG_1360 by Scott Carver, on Flickr IMG_1362 by Scott Carver, on Flickr IMG_1363 by Scott Carver, on Flickr Saw's out. IMG_1364 by Scott Carver, on Flickr NO GOING BACK NOW!!! IMG_1366 by Scott Carver, on Flickr What's interesting, I didn't plan this, is that the bottom of the cabin vents landed exactly where I cut the bottom of the bed out. I thought that was pretty cool. IMG_1367 by Scott Carver, on Flickr IMG_1368 by Scott Carver, on Flickr IMG_1369 by Scott Carver, on Flickr And it's done! IMG_1370 by Scott Carver, on Flickr Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted January 29, 2018 Author Report Posted January 29, 2018 Next step is to get the boot on it. IMG_1371 by Scott Carver, on Flickr First a little test fit. IMG_1372 by Scott Carver, on Flickr IMG_1373 by Scott Carver, on Flickr Man that looks so good! IMG_1374 by Scott Carver, on Flickr Another adventure. So if you can notice here, the boot is really wavy. Well that's because I got the wrong one. The edges that hold onto the sheet metal are supposed to be facing the same direction. These were not. So I ordered the wrong one, or they sent me a bad one, I'm not sure. But at this point, I was out of tie, I had a huge hole in my truck, and so I had to use it. IMG_1375 by Scott Carver, on Flickr IMG_1376 by Scott Carver, on Flickr I put some inserts in the rail to attach the enclosure to. Security thought. IMG_1377 by Scott Carver, on Flickr Holes in the wheel wells for anchor points in the enclosure. IMG_1378 by Scott Carver, on Flickr Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted January 29, 2018 Author Report Posted January 29, 2018 Now it's all in and the tops are temporarily secured for the drive to Sparks, Nv. IMG_1379 by Scott Carver, on Flickr IMG_1380 by Scott Carver, on Flickr Dedication, Stupidity, a combination of both? I don't know. We're now at Sky High Car Audio in Sparks, Nv and Jon was nice enough to let me back in and keep working. This is Friday, the day before the bbq. I think we got there around 10am on that day. We got right to work. My brother was with me, that's why I say we. Oh, and since we got there we finally had lugs to put on the cable. IMG_1381 by Scott Carver, on Flickr IMG_1382 by Scott Carver, on Flickr IMG_1383 by Scott Carver, on Flickr IMG_1384 by Scott Carver, on Flickr IMG_1385 by Scott Carver, on Flickr IMG_1386 by Scott Carver, on Flickr IMG_1387 by Scott Carver, on Flickr IMG_1388 by Scott Carver, on Flickr Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted January 29, 2018 Author Report Posted January 29, 2018 Next up was an exciting moment. Loading and wiring subs! IMG_1389 by Scott Carver, on Flickr IMG_1390 by Scott Carver, on Flickr IMG_1391 by Scott Carver, on Flickr All of a sudden, I hear this crazy loud motor, and the whole shop gets dim. I climb my way out from sitting in the enclosure, and this is what I see! IMG_1392 by Scott Carver, on Flickr IMG_1394 by Scott Carver, on Flickr Funs over, time to get back to wiring IMG_1396 by Scott Carver, on Flickr IMG_1397 by Scott Carver, on Flickr IMG_1398 by Scott Carver, on Flickr IMG_1399 by Scott Carver, on Flickr Thees are the terminals I was talking about earlier. IMG_1400 by Scott Carver, on Flickr IMG_1401 by Scott Carver, on Flickr Facebook Page: S99Creations 2006 F250 Lariat Build
Ron36 Posted January 29, 2018 Report Posted January 29, 2018 Great build I personally love how tight the box was in the bed keeps it lined up and won’t move, now need a Vid of that beast. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
