Wimpy subs are somtimes funny 2 look at. lets see m'!
#1
http://stores.channeladvisor.com/thedeepdi...%20STORE%20ONLY?
700 watts...
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
These DVC subwoofers are the most versatile drivers in the Dayton Loudspeaker line up. They were engineered to provide very good performance in sealed, vented, bandpass or even transmission line designs. The dual 8 ohm voice coils allow for use in a variety of applications and wiring configurations.
Each driver features a heavy gauge stamped steel frame, super stiff Kevlar impregnated paper cone, thick foam surround, flat progressive spider, vented pole piece, dual high power Kapton voice coils, heavy duty braided tinsel leads, and rubber magnet cover. Made in the U.S.A. 5 Year Limited Warranty.
Specifications: (Note: All specifications are with voice coils connected in parallel.) * Power handling: 350 watts RMS/per coil, 600 watts total * Voice coil diameter: 2" * Voice coil inductance: 1.81 mH * Nominal impedance: 8 ohm per coil / 4 ohm total * DC resistance: 2.60 ohms * Frequency range: 20-450 Hz * Magnet weight: 112 oz. * Fs: 20.4 Hz * SPL: 90 dB 1W/1m, 93.4 dB @ 2.83V/1m * Vas: 9.92 cu. ft. * Qms: 12.28 * Qes: .39 * Qts: .38 * Xmax: 15.1mm * Net weight: 20 lbs. * Dimensions: Overall Diameter: 15-1/8", Cutout Diameter: 13-7/8", Mounting Depth: 7-3/8", Magnet Diameter: 6-1/2".
SMDsigbannr4.jpg-
i got lightning audio promos from wal mart they are rated fo 760 watt max they hit pretty good my favorite was these cheap ass (jdaudio) 8" i had hook em to 1400 watt amp and made them smoke that shit was funny as hell
i'll bass race you with my tweeters
i'd wire them in series and put them on my homestereo
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Highly regret buying these subs only 700 watts
rims.jpg2 12" Kicker cvx1 proacoustic 4 now either quantum audio amp r Ma audio nextKenwood dash4 gauge wire pioneer in the doorsjvc in the back
Guest Disturb3d_pri3st
Hey are those qpower adrenaline subs.. if so i hope you didnt pay too much for them.. i had a deal where i could get em for under 20 bucks a sub for the 12's... they are some horrid subs man..
what model and/or year is the middle 1? & yea i heard the 1 in the left when they first came out at bestbuy. i was like "sounds like a 6 x 9"
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
yea that Team RF is a pretty wimpy sub
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 3081 Guests (See full list)
