thats definitey a big reason as to why you arent getting the movement you want from the subs on the power theyve got. more cone control from a small port for sure. Open that bitch up and those things will start flexing much more id be willing to bet.
Yeah right now my current port is 12.5 tall x 2.75 wide.
So I figured 13.5 x 3.75 (or 4 depending on my tuning) would be a plenty big increase in port area considering I want to keep my bandwidth as big as possible. I'm also increasing the box size to lower its f3 in the hopes of playing lower then 27hz with authority. And the kerf is half way for looks... But I figured with around 12sq inches of port per cube plus the kerf should insure no chuffing.
I'm excited for the rebuild.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
What's up with the tiny ports?
The kerf if he does it will offset that but I'm a fan of big ole ports
need port area to get loud.
Yeah that was the idea behind the rebuild. Considering how small my current port is and how small my box is I figured this design with the common port common loading plus all the extra space inside the box and bigger port would be a win in every possible way.
Any thoughts on the current design? Reference the numbers written down on paper above.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
I ran the same numbers as the drawn box above except a slightly larger port and I got
4.32 cubes
32.3 hz
54sq inches of port
12.5 inches of port per cube.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
put it this way, i was doing 153 sealed with 130 sq in of port. i could only play down to 30 though. so if you are trying to dip into the 20s well maybe you have what works. 2 12s just isnt enough cone to do it insane with a big port.
what you have may be good. but from my experience te bigger the better. then again i like the 35-45 choking bass. if i wanted 20s id get a bunch of 18s in a bandpass
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Brb, I'm gonna chop the back of my car off and do a wagon convert.
I totally disagree there. Literally yesterday, your on my Facebook Daniel.... I did some ref6.1 mids in the truck I built the 2 8's console box in with the embossed logo.
That bitch played takin chances like it was a joke. Just as well as Cameron loya's 8 15's 2:1 4th order, just 40db quieter. But for real. We were playing around with termlab and it did 124db at 23hz on takin chances. Peaked at 132.9 at 35 on wobble. Keep in mind this is on music at the headrest on about 400rms. LOL.
BESIDES THAT.... I have another surprise. I'm trying to figure out how to make a removable application for a second Zero1. I only want 1 amplifier daily, and I'd like to have a 5k at 1ohm or something of the sorts. Maybe even wire my zero1 that high, we will see. But for heatwave, I'll have 2 quattros and 2 zero1's at .5 stuffed in my trunk.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
So I did a full removal of the old system today.
Did a 100% rewire... Looks beautiful.
Did 80% of my deadening.
Steam cleaned all of my car.
Who wants pics?
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
**raises hand**
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
i never said you couldnt play it. but if its not moving air whats the point? shit my single 10 can play down to 16hz probably around 135. and 25hz and up nearing 140 or higher especially on the new amp i got. the issue is still not enough cone to really move air. to me anything less than 2 15s for low notes is virtually pointless (by low notes i mean sub 28hz). the closer you approach 20hz the less you can hear the note and mroe you can feel it. a single 10 or 2 8s even 2 12s doesnt allow you to fully feel it. so if its not music and you really arent moving much air whats the point to play that low?
BMW M340 xDrive
B2 FTW!! I also run a zero 1 .5 daily and love it had no problems with it whatsoever. The amp is a tank tuned in man
Youtube.com/J Hutch22
