Low idle and stalling out
Any idea guys ? Just recently started it
Will post video also when YouTube acts right
Rpms drop really low and sometimes dies and sometimes doesn't when I push the clutch in or I rev at all in neutral try to coast in neutral
So far I've cleaned the iac ,pcv valve , and tb will do the cai and maf today just ran out of daylight last night any ideas? Thanks guys
Mods:
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs,
5.0 Short Shifter
3.55 Gears
2002 Mustang GT Procharged
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Are those drive by wire or typical cable type TB? Was the vehicle actually tuned for the bigger injectors or just some type of out of the box programmer installed?
edit: does your car have an EGR system or did you remove it?
second edit: You have the right idea, anytime you have idle issues check for vacuum leaks, EGR, IAC, MAF, o2 sensors, TB seals, etc.. Typically an idle issue is caused my extra air not coming through the MAF. I had a similar issue I had to trouble shoot with my Evo IX after my build, it would drop idle really low coming up to a stop light when I depressed the clutch, let the idle drop on my large injectors, and then of course using the brakes.
If you have any kind of data logging device you can check the values of certain sensors. Look up on some forums what normal values should be and compare to what you have. I don't know what trademark name is out there for your vehicle, but equivalent of EvoScan or EFILive
John
Not really sure he said he had it tuned the injectors were added
To it before I bought it it's been running fine just started this yesterday
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
check the EGR valve, and I recommend removing it in any performance vehicle anyways, so look into whatever options the mustangs have for that. Sometimes it just a blocker plate slipped between the EGR valve and intake manifold, and sometimes it's complete removal of the system which requires capping the vacuum lines and getting a plate.
No manifold leaks I'm thinking a really nasty cai or maf ganna pull those out of the fenderwell today and clean both if that fails im thinking a bad iac other than that I'm baffled
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Didn't mean 02 sensors ?? but I highly doubt it's the 02 sensors
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
You took out your oxygen sensors?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Been trying to read around and a lot of people with similar problems are saying maf , I've already cleaned pcv valve ,tb, iac and have had no luck yet I fired it up this morning and seemed fine but usually doesn't start until it's warm I'll see this afternoon . The cai is disgusting no idea when the last owner cleaned it so I'm ganna hop on that today
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
