akuma4u Posted June 14, 2015 Report Share Posted June 14, 2015 Ive heard 3 things about running the subsonic filter for sealed boxes 1) its not needed so just leave it off or the dial all the way to the left (around 15hz for most amps) the box will take care of the filtering of super low frequencies itself 2) for sealed, it should be set to 25-35hz 3) it should be set to the lowest frequency the sub is able to play (i.e if the sub is rated to do 22hz-200hz) then the SSF would be set to 22hz) so which option is the right way to go? thanks Link to comment Share on other sites More sharing options...
khinds94 Posted June 14, 2015 Report Share Posted June 14, 2015 Not needed 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt Link to comment Share on other sites More sharing options...
firebirdude Posted June 14, 2015 Report Share Posted June 14, 2015 A sealed enclosure's natural rolloff is plenty. Link to comment Share on other sites More sharing options...
SnowDrifter Posted June 14, 2015 Report Share Posted June 14, 2015 You don't need to use it. Your SSF is there to prevent uncontrolled mechanical movement when playing below tuning in a ported enclosure. Sealed boxes don't unload, so there's no need. It's not going to hurt anything if you use it so you sleep better at night, just know it's not serving much of a purpose in this scenario ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
akuma4u Posted June 14, 2015 Author Report Share Posted June 14, 2015 well to all u guys saying u dont need it, what about this post: http://www.stevemeadedesigns.com/board/topic/156565-how-to-set-your-subsonic-filter/ "In a sealed box: The lower the frequency, the more excursion your subwoofer exhibits in order to play it loudly and accurately. A sealed box is tuned by enclosure volume, larger enclosures tune lower, smaller enclosures tune higher.Subsonic frequencies potentially damage your subwoofer because they make it expend a lot of energy, travel right to the limits of its excursion and play below the enclosures tuning.So for safety, we want to cut those frequencies out. For a sealed enclosure you adjust the subsonic filter to 25-35 Hz, to filter the extremely low bass frequencies your woofers unable to play." Link to comment Share on other sites More sharing options...
islandpride684 Posted June 14, 2015 Report Share Posted June 14, 2015 Set it to 30 and your good to go... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
