4x6 speaker recommendations for S10
SMF93
Read online that the depth is 2&3/16
Not sure if its right, i will check in a little bit and let you guys know
Assuming you will be running these speakers off headunit power...
rockford fosgate punch 4x6 have only 1-7/8" depth
http://www.sonicelectronix.com/item_19560_Rockford-Fosgate-Punch-P1462.html
since you will have the speakers out put some deadener in there!
http://www.sonicelectronix.com/item_3128_Dynamat-Xtreme-Speaker-Kit-10415.html
Do you know what's under there? Nothing to even put deadener on besides the heater box
the 2 sheets in door speaker kit is meant to go around the hole, not in it
Audio-Barrier-Speaker-Kit-detailed-image
I have a small U.S. merlin amp running to my door and dash speakers
^That is a 4x6 for the dash
That is for sure a door but I think it was just an example of deadener placement.
There isn't that much space around the dash speaker though and deadening what is there likely would make no difference at all.
adding deadener around the speaker opening will reduce vibrations and reduce speaker panel distortion,
it is smart to take care of this while you have your speakers out anyways
the picture is of a door and not a dash but was used to show how the kit is meant to be used.
goodluck!
  • Who's Online   1 Member, 0 Anonymous, 1051 Guests (See full list)
