Port area. what does it affect?
Port compression. Same as acoustic compression.
Please tell me how having over minimum area hurts the output of a speaker.. I don't care at all about location restraints.
He's not asking if a little over the minimum required area would hurt it he's asking how much is too much and what would it effect if it was too much.
or.. what happens if your AT MIN...
and what is MIN?
An isobaric sub has no port to connect the chamber to the outside so port area in no was would cause that.
At some point if the port is freaking huge the sub might as well not be in an enclosure right?
Say 500sq in of port for an 8" sub what's going to happen?
The port helps control cone movement right?
So what happens when the port is too big to have an impact on cone control?
How much bigger does it have to be for that too occur?
Okay going to scratch over the too much since it isn't the question right now.
Minimum port area can be found from a few variables of your system such as cone area in total, xmax and tuning frequency.
Using this:
Calculate the minimum port diameter from the following equations:
Sd = pi*(Dia/100)^2/4
Vd = Sd*Xmax/1000
Dmin = 100*(20.3*(Vd^2/Fb)^0.25)/Np^.5
where,
Dmin = minimum port diameter (cm)
For vented type speakers operated at full power that is, full excursion, it is possible to end up with audible noise from the air rushing in and out of the vent. For a given speaker system, the smaller the vent opening the greater the velocity of air in the vent and the greater the vent noise.
The main reason this ever became a topic is because Richard Small (the S in T/S Parameters) wanted to know the minimum velocity the air from the port could have without causing noise. This happens to be about 5% the speed of sound. That formula should get you close to it, but with modeling software you don't really need to use it, just make sure your port velocity is down.
There are other negatives from port compression such as added heat from inadequate air transaction and poor frequency responses due to it as well.
Krakin's Home Dipole Project
No
You have a large port
Yes
That's like saying when does an engine have too much horse power to not move a car.
All of that works the other way around, the port looses the ability to control cone movement with too little port area and playing below the tuned frequency.
Using this:
Vd = Sd*Xmax/1000
where,
power applied ?
Doesn't matter, you shouldn't be playing a sub past it's Xmax anyway.
The Xmax is there to have it know your upper limit of excursion.
If you use less power you'll have less excursion to cause less air to move. So you could use a smaller port area, but when designing you design around your speaker not your amplifier, because what if you get a bigger amp.
If you could have too much port area then playing speakers at low volumes would sound absolutely horrible as the port area needed gets exponentially smaller as you use less power.
So a sub doesn't unload at high volume with too much port area because that's what I've heard in the past.
I think we all know too small and you have port noise.
  • Who's Online   1 Member, 0 Anonymous, 399 Guests (See full list)
