Alternator Whine issue *figured out* UPDATE pg.11
issue figured out? so it was RCA's?
I dont think it was the RCA's because im getting the same issue with these RCA's. Im going to do more testing today but I already sent in a warranty request form to Droppin HZ because im pretty sure its the amp.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Don't remember and I'm on mobile right now, but did you try a different amp to see if the whine was there?
I did but it was a monoblock amp. I didnt hear any noise come out but I wasnt sure if it was the filter filtering out the noise.
I know there's gotta be someone you know with a four channel you can borrow for two minutes
Sadly noone that is around here does that I personally know. Im going to get one off of CL and test it with that.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
No they are different. The ones that are ran are stinger twisted pair and the ones I will be running are SHCA coax.
Twisted rca vs Coax. Are you using the right one's. Watch the video.
https://youtu.be/QOagVDZLQnA
Yeah I watched it and I had the issue with both RCA types. The RCA's work fine with the sub amp.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Not anywhere that is with 40 mins sadly. Im going to look around and see if anyone will let me use theirs for a bit
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Okay so I found an amp to try out and I'll be doing that tomorrow. I'll let you know the outcome.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Cool. Knew there had to be someone that could let you test t and you not have to shell out money for an amp to try it with
Yeah. I did find a crossfire amp on CL for $60 and if I do need to send my amp in I might go pick it up song still have mids/highs. Tomorrow I will also take pictures of all of my wiring bc I know some of you wanted to see that.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
