BigManAC Posted June 15, 2015 Report Posted June 15, 2015 Alright SMD family I done just about all I can think of but maybe yall can see something that i'm overlooking. Here's the rundown and what I have tried. Basicly I am getting a low volume alternator whine, once the volume is turned up loud enough you can't hear the whine until the rpms get above 3k. This is what I have done so far: 1) Plugged an iPod directly into the amp - no whine 2) Plugged an iPod into the RCA's at the HU running to the amp - no whine Those two test lead me to believe that it is not an amp grounding issue, so must be somewhere near the HU. My factory harness where the aftermarket one plugs into for the radio adapter was a hack job from the previous owner and when I would bump it the whine would get worse so I ran to the salvage yard and picked up a new one and now thats fine. However the whine is still there. 3) I ran a ground from the HU to the battery up front with 16g wire - whine is still there Could it be the HU preouts are bad? Any advice is appreciated. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
reedal Posted June 16, 2015 Report Posted June 16, 2015 Strip the jacket off of some wire and run it around the outer shield of the RCA jacks on your HU. Like this What HU do you have? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Kyblack76 Posted June 16, 2015 Report Posted June 16, 2015 you sure its alt whine? unplug the alt and see what happens.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
deathcards Posted June 16, 2015 Report Posted June 16, 2015 have you tried grounding else where other than the battery have you checked the pico fuse skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
n8ball2013 Posted June 16, 2015 Report Posted June 16, 2015 If it's a pioneer and you posted this I hope you step on a. Rusty nail THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Guest Posted June 16, 2015 Report Posted June 16, 2015 make sure everything is grounded at one point...amps, head unit etc. It is most convenient to run a ground wire from your amp(s)/rear battery to the front battery negative. This worked for me. I was in your same situation.
Kyblack76 Posted June 16, 2015 Report Posted June 16, 2015 make sure everything is grounded at one point...amps, head unit etc. It is most convenient to run a ground wire from your amp(s)/rear battery to the front battery negative. This worked for me. I was in your same situation. cool... my 22 grounding points to one point... check.. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Guest Posted June 16, 2015 Report Posted June 16, 2015 make sure everything is grounded at one point...amps, head unit etc. It is most convenient to run a ground wire from your amp(s)/rear battery to the front battery negative. This worked for me. I was in your same situation. cool... my 22 grounding points to one point... check.. I didn't literally mean one point...I meant like ground everything in the front for instance instead of having some things grounded in the front and some in the back etc... every car is different...but it worked on mine..no more noise
Kyblack76 Posted June 16, 2015 Report Posted June 16, 2015 it worked t make sure everything is grounded at one point...amps, head unit etc. It is most convenient to run a ground wire from your amp(s)/rear battery to the front battery negative. This worked for me. I was in your same situation. cool... my 22 grounding points to one point... check.. I didn't literally mean one point...I meant like ground everything in the front for instance instead of having some things grounded in the front and some in the back etc... every car is different...but it worked on mine..no more noise I dont have alt whine..... so.. some in the front? and some in the back?.. got ya SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
