blross91 Posted June 19, 2015 Report Posted June 19, 2015 After installing my 250 amp alt. I have a battery not charging code pop up on my dash. I check my volt meter,and use a multimeter and both said 15 volts but after a while itll drop to 12 and the car shuts off. Has anybody had similar issues?
gdaigle Posted June 19, 2015 Report Posted June 19, 2015 Have u called DC? Is it the 250hd? System: Pioneer DEH-8400BH 4 Alpine Type R 6.5's 4 Soundqubed PA 6.5's 4 Soundqubed Supertweets Hifonics BRX 640.4 Crescendo S800/4 2 Soundqubed Q1-3500.1s strapped @1ohm 2 Soundqubed HDC4 18's 11 Cubes net @37hz (Subs up, port back) 2 DC Power 250 HD's 1 DC Power 300 SPX DC Power triple alt bracket 5 Kinetik HC 1800's 4 runs of 1/0 OFC power cables 4 runs of 1/0 OFC grounds from rear battery bank to OEM alt bracket iPad Air in dash 300+ sq ft or sound deadening
reedal Posted June 20, 2015 Report Posted June 20, 2015 Did you wire the stock charging wire back on to it? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
blross91 Posted June 20, 2015 Author Report Posted June 20, 2015 Its a 250 xp. And yes i put the fuseable link back on it. Also im looking at where you make the connection with the wiring harness. And it only had 3 pins. The stock alt has 4.. could this be the problem?
blross91 Posted June 20, 2015 Author Report Posted June 20, 2015 And no i haven't contacted them. Tried installing yesterday and by the time the problem occurred they was closed.
gdaigle Posted June 20, 2015 Report Posted June 20, 2015 You always want to upgrade your charging wire/do big 3 when installing high output alts. I would call DC on Monday. System: Pioneer DEH-8400BH 4 Alpine Type R 6.5's 4 Soundqubed PA 6.5's 4 Soundqubed Supertweets Hifonics BRX 640.4 Crescendo S800/4 2 Soundqubed Q1-3500.1s strapped @1ohm 2 Soundqubed HDC4 18's 11 Cubes net @37hz (Subs up, port back) 2 DC Power 250 HD's 1 DC Power 300 SPX DC Power triple alt bracket 5 Kinetik HC 1800's 4 runs of 1/0 OFC power cables 4 runs of 1/0 OFC grounds from rear battery bank to OEM alt bracket iPad Air in dash 300+ sq ft or sound deadening
Miguels Posted June 20, 2015 Report Posted June 20, 2015 you dont upgrade you add my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
gdaigle Posted June 20, 2015 Report Posted June 20, 2015 What I meant... System: Pioneer DEH-8400BH 4 Alpine Type R 6.5's 4 Soundqubed PA 6.5's 4 Soundqubed Supertweets Hifonics BRX 640.4 Crescendo S800/4 2 Soundqubed Q1-3500.1s strapped @1ohm 2 Soundqubed HDC4 18's 11 Cubes net @37hz (Subs up, port back) 2 DC Power 250 HD's 1 DC Power 300 SPX DC Power triple alt bracket 5 Kinetik HC 1800's 4 runs of 1/0 OFC power cables 4 runs of 1/0 OFC grounds from rear battery bank to OEM alt bracket iPad Air in dash 300+ sq ft or sound deadening
blross91 Posted June 20, 2015 Author Report Posted June 20, 2015 What about the pins inside the wiring harness. The stock alt had 4 and the dc powers has 3
Broke_Audio_Addict Posted June 20, 2015 Report Posted June 20, 2015 Did you do the big 3 or just hook it up with the stock wiring? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
