SIDE SHOW Posted June 22, 2015 Report Posted June 22, 2015 also what are you running from the amp? at what ohm?
Inetba Posted June 22, 2015 Author Report Posted June 22, 2015 I am running a DD 3515 at 2 ohms. The car is running. It dims at idle, it dims at 2k rpm, it dims at 4k rpm. The amp is going into protect. According to the manual that came with the amplifier it is going into "low voltage protect" and it doesn't go into low voltage protect until it hits 10.5 volts.
Inetba Posted June 22, 2015 Author Report Posted June 22, 2015 I know the amp going into protect and the lights dimming are related. It's because of low voltage. What I don't understand is WHY I'm getting low voltage. My RPMs are high. My alternator is HUGE. I really hope it's not an alternator problem because I paid $600 for the thing.
SIDE SHOW Posted June 22, 2015 Report Posted June 22, 2015 OUCH... yeah wouldn't think it would be that, how olds your battery and just check your inline fuses/earths ect are all tight
Inetba Posted June 22, 2015 Author Report Posted June 22, 2015 Battery is one week old, I'm thinking of unplugging the ELD tonight. See if that helps.
Inetba Posted June 22, 2015 Author Report Posted June 22, 2015 Hondas come with this stupid thing that turns off the alternator until the battery voltage drops to like 12.5v. It's to improve gas mileage but it can cause issues with big amplifiers. I disabled the ELD and the dimming stopped, but now the amp goes into protect at 22/35 and stays there unless I turn the volume down. I have a feeling it's because I need a bigger wire from the battery to the amp. The current wire is 4 gauge. I believe.
SIDE SHOW Posted June 23, 2015 Report Posted June 23, 2015 Yeah that could be the problem, I thort you had 1/0gauge.... still the 4 gauge should be enough. least the dimming had stopped
Kyblack76 Posted June 23, 2015 Report Posted June 23, 2015 some one post the eld bypass SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
DTS909 Posted June 23, 2015 Report Posted June 23, 2015 Did you cut the original alt plug and wire a new one? Maybe wired incorrect. VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
